help with electrical issue
Old Nov 5, 2013 | 11:01 PM
kellym's Avatar
kellym is infamous around these parts
Hi there, I'm having strange electrical issues and wondering if someone here has some suggestions. Symptoms:
- Warning: Check Battery / Alternator light has come on sporadically for months. Happens once every 5 to 10 times I start the car. If I stop and re-start, the message goes away.
This morning for the first time many more things went wrong:
- Exterior Temp Sensor Warning, beeps every 30 seconds or so
- Warning: ABS failure + flashing lights
- Warning: PSM failure + flashing lights
When I stopped the car, it refused to start. I had a new Interstate battery installed this summer. I had a new battery-alternator cable replaced under warranty and part of a factory recall this spring.
The battery was almost dead, yet it had been fully charged just a few hours prior using my Porsche brand dual-mode trickle charger... it had been charging for days... and now my 911 would only make clicking noises when I tried to start it. I called AMA for a battery boost and potential tow (since my certified pre-owned warranty has recently expired)... the boost brought it back to life and I drove straight to the dealership. They seemed perplexed and will spend a few hours to diagnose the issue.
Alternator? Computer? Cabling? I'm inclined to think it's a faulty alternator, but I'm no expert.
The car is a 2005 C2S and it rocks otherwise!
Old Nov 5, 2013 | 11:22 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Do a quick charging test (no-load and load tests). It sounds like your alternator isn't charging your battery.
Some Schumacher battery chargers also have an alternator test switch. Mine does and it makes things convenient.
Good luck
Old Nov 6, 2013 | 01:42 PM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
The alternator cable harness has a known issue. With age and heat from the engine bay, the resistance of the original cable increases. This causes a voltage drop from the alternator to the battery. Bottom line the battery does not see a full charging voltage.
Check the voltage output at the alternator. Check again at the battery. If the voltage drops more than 0.5V, consider having the alternator battery harness changed out to the updated version.
Another thing to check is your battery's age. Your car is a 2005. How old is the battery?
Old Nov 6, 2013 | 01:49 PM
Robocop305's Avatar
Robocop305 is just really niceRobocop305 is just really niceRobocop305 is just really niceRobocop305 is just really nice
I would also have the battery checked. I had a similar issue and the culprit was the battery.
Old Nov 6, 2013 | 02:43 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
[QUOTE=kellym;3974383]Hi there, I'm having strange electrical issues and wondering if someone here has some suggestions. Symptoms:
Either a dead cell in the battery or, more likely, the alternator is going/gone. If you can start the car, check alternator out put (if the alt/bat harness was replaced it's not likely the harness causing the voltage drop.) If the engine will not start check the battery for a dead cell either at home if have the equipment, or at the place you bought it. If it checks out you need to have the alternator bench tested to confirm it's the problem.
Old Nov 26, 2013 | 09:18 PM
kellym's Avatar
Just a quick update in case anyone is interested. It was the alternator. I already put in a new battery and new battery-alternator cable, and the dealership confirmed the alternator was faulty. Works good now, although it's $1,600 later...
Old Nov 26, 2013 | 09:41 PM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
Painful
Old Nov 26, 2013 | 09:53 PM
cab83_750's Avatar
Cool. Problem solved---congratulations.
For everyone else, IMO, i believe that without much mechanical skills, anyone can replace their alternator. Expect about $175 for someone to rebuild it.
Old Nov 26, 2013 | 09:55 PM
cab83_750's Avatar
Would you mind posting you mileage?
Old Nov 26, 2013 | 10:27 PM
kellym's Avatar
Sure, it has just over 30,000km which is 18,700 miles. But it's a 2005. Still, pretty early for an alternator to go in my opinion.
I wish I'd known the alternator is easy to replace, I could have done it myself or with a friend's help. I took it to the dealer because I know electrical problems can sometimes be very hard to diagnose. Peace of mind that it's fixed again at least.
Old Nov 26, 2013 | 11:08 PM
cab83_750's Avatar
Yours is one of the lower mile failure. They average around 50k iirc. Mine failed a few weeks before yours (@ 56k miles).
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
Rockinc1
Sep 30, 2015 06:44 PM
cm09578
Sep 22, 2015 06:07 AM
