Extreme cold trouble starting
Old Dec 7, 2013 | 10:52 AM
Bdal451's Avatar
Bdal451 is infamous around these parts
Hello
I just returned from a week long business trip, I parked my 997.2 c4s in the airport garage as usual. It was extremely cold while I was gone eg -15 at night and only low single dits during the day. When I got to my car it would not even turn over although the batter appeard to have enough power for lights etc. I tried several time waited tried again. Finally it did start. Any ideas here. Should I expect this again? Car is a2009.
Old Dec 7, 2013 | 12:10 PM
jhbrennan's Avatar
Originally Posted by Bdal451
Hello
Time for a new battery.
Old Dec 7, 2013 | 12:24 PM
PTParks's Avatar
PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !
Agreed. I'm not facing any weather conditions near what the OP was faced with and I have already replaced the original battery in my '09. Plus I bought a battery maintainer for when the car is in lay-up mode.
Old Dec 7, 2013 | 12:50 PM
Fahrer's Avatar
Fahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to all
Modern cars can fool you with the ability to light the headlamps while actually having not enough power to start the car.
Old Dec 7, 2013 | 02:13 PM
DallasDave's Avatar
DallasDave is infamous around these parts
As the others have stated, you are describing the need for a new battery. If it is the original, you have gotten your monies worth from an '09 installed battery.
I recall the dealer charge for replacement is around $500.
Good luck,
Dave
Old Dec 7, 2013 | 02:20 PM
PTParks's Avatar
Good luck,
Dave
I paid around $110 for a porsche-specific battery at Auto Zone. Don't remember the guarantee specifics, but they were more than adequate.
Old Dec 7, 2013 | 02:34 PM
jhbrennan's Avatar
No need to spend $500 when you can get a better battery and warranty with a Wal-Mart or Interstate H7 for less than $150.
Old Dec 7, 2013 | 02:40 PM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
+1 on walmart H7,,works perfect, fits perfect..
Old Dec 7, 2013 | 02:52 PM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
It sounds dumb to say, but just be carefully and don't put it in backwards. It's easier to get it wrong than you'd think.
Old Dec 7, 2013 | 04:17 PM
tiyyara's Avatar
tiyyara is infamous around these parts
I changed the battery on my 09 in the summer.
I got the Porsche branded battery, the car was at home, picked it up and installed it myself. Hindsite, should have saved the 100USDs and got an H7 at walmart like everyone else.
I have a 100 USD porsche label on my battery, :-)
Old Dec 7, 2013 | 04:31 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
As everyone said, most likely your battery (CCA or cold cranking amps).
Careful with your back. I have a good back but that puppy could be heavy due to the location. Don't forget to connect the drain hose --- or don't lose it (nipples and all).
Old Dec 7, 2013 | 04:56 PM
Bdal451's Avatar
Walmart h7
Sounds like a great battery. Is the drain hose difficult to reconnect? Perhaps there is simple DIY? Or maybe is so simp,e a DIY is a ridiculous idea
Old Dec 7, 2013 | 05:01 PM
cab83_750's Avatar
It should be ez. Just make notes of the connections. A lot of people here forget the drain tube or lose the nipple.
henryr
Sep 24, 2015 08:22 PM
ritchrwi
Aug 29, 2015 08:27 PM
gulf gt
Aug 27, 2015 10:27 AM
