Depress clutch message and intermittent starting issues
Old Mar 5, 2014 | 03:11 PM
Rporsche's Avatar
Rporsche is infamous around these parts
Exclamation Depress clutch message and intermittent starting issues
Hi!
I have 911 Carrera 4 2009, different posts on the web discuss that if you have intermittent starting problems and a 'Depress Clutch to start' message on your dash, you may need to replace the clutch switch.
I am finding out that there could be more than one switch - which is the one that affects the manual start? I am hoping some in the forum can help!
Thanks in advance!
RCharles
Old Mar 5, 2014 | 04:34 PM
Scrambler8's Avatar
Scrambler8 is infamous around these parts
I am glad you posted this issue. I don't know if I have the same problem. I have had my 2006 C4S for a couple of weeks and due to weather I have not had much opportunity to drive it. However, there were two instances where I depressed the clutch (fully I thought), turned the key and the car would not start. Maybe it's me and I did depress the clutch enough, but I am curious if more people are having this problem.
Old Mar 6, 2014 | 08:34 AM
tiyyara's Avatar
tiyyara is infamous around these parts
There is a TSB for that and your dealer should replace it.
If he gives you a hard time PM me and I can send you a scan of the workorder/sheet
Old Mar 6, 2014 | 09:04 AM
Scrambler8's Avatar
tiyyara - Thanks for the reply. I called my dealer and talked with the service department. They acknowledged that there is a switch at the clutch that may fail and result in a non-start. They will replace it at no charge under my CPO warranty.
Old Mar 6, 2014 | 01:43 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
what years are we talking about for that TSB? I ve had my 09 at the dealer several times for various things and they never mentioned it.
Old Mar 6, 2014 | 02:42 PM
porschelady's Avatar
porschelady is just really niceporschelady is just really niceporschelady is just really niceporschelady is just really niceporschelady is just really nice
our '08c4 does that intermittantly. I thought it was just me screwing up.
Old Mar 6, 2014 | 02:53 PM
tiyyara's Avatar
It is s service campaign TI-10-12. This is what I found whilst searching on the phone.
I will send in the "real" info once I get home.
Old Mar 6, 2014 | 04:51 PM
Scoper's Avatar
Scoper has a spectacular aura aboutScoper has a spectacular aura aboutScoper has a spectacular aura about
I had my clutch depress switch changed twice - once when I first took delivery of the car, another time about a year ago. It's not an uncommon issue.
Old Mar 6, 2014 | 05:08 PM
cerbomark's Avatar
so is there something that can be done not to be stranded if this happens..???
Old Mar 6, 2014 | 05:34 PM
tiyyara's Avatar
Here it is, reading.typing from work order/invoice
Replacing Clutch pedal switch
WC09 Replacing Clutch Pedal Switch
1 000-043-207-86 switch
22766 performed campaign WC09. Replacing clutch pedal switch 10TU
I hope this helps all of you who need it!
Old Mar 6, 2014 | 05:49 PM
Scoper's Avatar
You can get into the footwell and feel around for the actual switch and press it by hand. It's really awkward, though. That's how I got my car to start when the switch was failing the first time. If manually pressing it all the way in didn't work, I think I read that someone shorted the terminals of the switch with a wire, bypassing it.
Just make sure you're in neutral when you do either of these workarounds. If you are in gear and you bypass the switch and turn the key, the car will jump forward. (That's why these switches are in all cars with clutch pedals. I just don't know why the Pcar switch is prone to be faulty..)
Old Mar 6, 2014 | 05:58 PM
cerbomark's Avatar
thanks, good to know. All 6 speeders should know this.
Old Mar 6, 2014 | 06:49 PM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
I think Durametric Pro can turn this message off. I know my MT coupe does not display any "press clutch" messages on startup. Haven't tried to start it without pressing it in though....
Old Mar 13, 2014 | 10:17 PM
Volnomad's Avatar
Volnomad is infamous around these parts
It is my understanding that the car will start despite a faulty clutch switch if you hold the key in the start position for 30 seconds. It worked on my wife's 2008 Boxster S.
Old Mar 14, 2014 | 05:08 AM
cerbomark's Avatar
another good thing to remember to maybe avoid a tow.
gulf gt
Aug 27, 2015 10:27 AM
magoochi
Aug 23, 2015 05:54 PM
plenum
Aug 21, 2015 10:02 AM
JMon
Aug 21, 2015 08:20 AM
