Changing radiator control module or fan itself?
Old Mar 5, 2014 | 07:14 PM
MJRizzo's Avatar
MJRizzo is infamous around these parts
It seems like I'm having a failure of my radiator cooling fan ( drivers side ) or its control module . For the second time in a few weeks when pulling into garage the fan on passenger side was blowing at full speed ( very loud ) and no air was coming out of drivers side. Is there any way besides removing bumper to get to that control module or fan itself ? Thanks to all in advance. You have all been so much help already
Old Mar 5, 2014 | 09:30 PM
Jam996's Avatar
Jam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud of
As I replied to your other thread :
I had the same issue, only one fan on with loud noise...You do have to Remove bumper and clean the area, if needed clean between radiators too. Its best to install mesh grill on bumper to avoid this problem in future. if you need instructions on removing bumper let me now.
Old Mar 6, 2014 | 04:45 AM
MJRizzo's Avatar
Instructions would be great ...
Old Mar 6, 2014 | 12:15 PM
devil boy's Avatar
devil boy is infamous around these parts
You can access the fan from the wheel well. After you remove that plastic trim, stick your hand up there and see if the fan freely spins. If it's stuck you might have a rock or something jamming it and by spinning it you might break it free from the obstruction. I had a rock wedged between my fan blade and the outer shroud. If the fan already spins freely then it might be the controller.
Old Mar 6, 2014 | 04:04 PM
forbes210's Avatar
forbes210 is infamous around these parts
Had similar issue with my car. One of the fun wasn't working and car was overheating in slow traffic. I took it to the dealer to inspect it. during the inspection and found out that it was jammed and they were able to free it and its working fine till today. I doubt that you have to remove the bumper since the dealer charged me $60 for inspecting the problem. To remove the front bumper you will have to put significant amount of labor.
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
LiquidElephant
Aug 27, 2015 06:17 PM
00aston
Aug 27, 2015 12:01 AM
