Do we need to clean the brakes regularly?
Old Apr 9, 2014 | 12:54 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Do we need to dismantle our brakes to clean them every so often? Im getting some brake squeal which really was not there when new. I am now thinking of dismantling them putting some grease there and cleaning them. Is this a maintenance thing on our brakes?
Old Apr 9, 2014 | 01:30 PM
killacam's Avatar
killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !
are your pads worn? does it only squeal when you apply the brakes?
Old Apr 9, 2014 | 02:57 PM
Super Adjuster's Avatar
Super Adjuster has a spectacular aura aboutSuper Adjuster has a spectacular aura about
I blow the dust out of the discs and calipers before washing the wheels. Lot's of dust comes out!
Old Apr 9, 2014 | 03:56 PM
Pads are not yet worn, 30k kms on them, and yes they squeal only whenyou apply the brakes.
Old Apr 9, 2014 | 05:23 PM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
You're probably not braking hard enough during normal drives. Try bedding them and report back.
Old Apr 9, 2014 | 09:07 PM
Matt(inMA)'s Avatar
Matt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud of
Yes, after every drive.
Old Apr 9, 2014 | 11:33 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Hose them a lot once a week. If I don't hose them once a week, they tend to make noises. Also, I don't have the brake applied so that the calipers aren't in contact with the rotors.
The grease should last between pad changes.
Old Apr 10, 2014 | 07:14 AM
Actually cab, whenever i clean the wheels, there is a lot of dirt in the wheels. Maybe i will try to hose the wheels down and use a strong spray of water on the hubs and pads to wash off brake dust and dirt. Will do this first and report back. THAnks cab
Old Apr 10, 2014 | 09:54 AM
cab83_750's Avatar
Shoot water throughout the the caliper, rotors, etc. Our rotors are slotted and drilled. Make sure you get water through the holes too. Drive it a few blocks afterwards to dry everything and avoid rotor surface rusting.
I also noticed that you have new pads. I never had issues with squeals from new pads, though I do the bedding as soon as I replace the pads.
Old Apr 10, 2014 | 10:14 AM
ACRB's Avatar
ACRB is infamous around these parts
I thought that the common cause for break squeal is an issue with the rotors. If new pads are put on, and the rotors are slightly worn you will get a squeal. I don't think hosing them off will make a difference.
Old Apr 10, 2014 | 01:04 PM
cab83_750's Avatar
A lot of causes for brake squeal (type of pads used, dust, rusted hardware, dirt, etc.). Cleaning the dust is the quickest and cheapest way to diagnose the issue (and I don't like to blow the dust as I might inhale that crap; water, I think, is safer). No need to take things apart when a 5 minute no-brainer first-step task 'could' solve the problem.
I have worn rotors with new pads. I installed new pads, drove the car to the recommended bedding process, and no squeal.
For reference, I have had squeals ever since my car was new to me. The squeal starts if I don't wash the car once a week.
I'mAllIn
Sep 11, 2015 06:38 AM
