Noise from dash when Aircon is running
Old May 22, 2014 | 02:12 PM
AlfieM's Avatar
AlfieM is infamous around these parts
Hi All
I have a 2005 997 s which has developed a noise when the air con is running. The temp is nice and cold but there is a strange noise or groan after it has been running for a 5-10 mins
It isn't the fan as the noise stops if I press the eco button
It would be great if any of you kind please could shed some light on this issue
Many thanks
Old May 22, 2014 | 03:35 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
AC unit has fan and compressor. If it is not the fan that leaves the latter. Fwiw, I have no groans just an occasional "gurgle". Checked coolant level?
Old May 22, 2014 | 03:44 PM
AlfieM's Avatar
thank you for your reply
I forgot to mention that the noise is coming from behind the dashboard?
Old May 22, 2014 | 05:14 PM
Gpjli's Avatar
The noise I get is from there too but usually I hear it when turning it off. Not really a moaning but hard to describe sounds. Ghosts in the Machine? If it is cooling well perhaps not to worry.
Old May 24, 2014 | 04:54 PM
ecostellodo's Avatar
ecostellodo is infamous around these parts
If you have had the AC serviced, it could be air in the line.
Old Feb 20, 2019 | 01:08 PM
chopperharris's Avatar
chopperharris is infamous around these parts
Hi
My 997 does the same thing. I get a intermittent groaning noise after the car has warmed up. It goes away when you turn the air con off. It’s appears to be coming from the air con pipes resonating at the front of the car near the evaporator valve (behind the dash).
Did you find out what was causing your issue?
Cheers
Ben
Old Feb 25, 2019 | 07:54 PM
997-318touring's Avatar
997-318touring is infamous around these parts
Originally Posted by chopperharris
Hi
Cheers
Ben
I had to replace the fan blower that is behind the glovebox. Luckily someone from Rennlist, who'd been building a race car, sent me his surplus blower for free! He was in America and I'm in New Zealand. That's the spirit of the Porsche community.
Anyway, quite easy to replace. Remove the glovebox, remove old blower, unplug power, plug new one in, installation is reverse of removal.
Jul 29, 2019 11:13 AM
riverflyer
Sep 1, 2015 04:22 PM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
Zero911
Aug 24, 2015 06:51 PM
