Exhaust leak or other problems?
Old May 26, 2014 | 07:16 AM
vg247's Avatar
vg247 has a spectacular aura aboutvg247 has a spectacular aura about
Recently I've noticed that my polished exhaust tips tend to get much more dirtier on the right side compared to the left side tips.
Is this normal, or is this indication that my exhaust has leaks some where and the exit exhaust flow is not even on both sides, or perhaps other issues?
I have Fistered side cans installed by Darren and a Sharkwerks center bypass on my 997.2 car. Haven't noticed any loss in power then again I just got back in the country and haven't spent time driving as much.
Thanks in advance.
Old May 26, 2014 | 07:42 AM
Domer911's Avatar
Domer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond repute
as far as I can tell, that's normal.
Old May 26, 2014 | 08:02 AM
vg247's Avatar
Thanks Domer911
Old May 27, 2014 | 12:54 PM
StormRune's Avatar
StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !
I have not seen any imbalance between the right vs left on either my prior 997.1 or my 997.2, and I tend to keep my tips pretty clean around the outside and inner lip (where it normally gets sooty after a while if not cleaned) so I would have noticed. I had the Fabspeeds with the angled inner edge on the 997.1 and liked to keep them shiny.
Old May 27, 2014 | 04:03 PM
vg247's Avatar
Appreciate your input Storm,
I wonder if there's something to easily check in my case to confirm everything is okay or whether it's really normal. I have the Fabspeed polished quad tips and the right side tips were remarkably dirtier than the left tips after driving just 100miles post car wash.
Old May 27, 2014 | 08:34 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
mine get evenly dirty or blackish due to the exhaust. I have noticed other DFI cars such as a friends BMW that one side was clean and the other dirty as you stated. ???
subscribed for the answer.
Old May 27, 2014 | 08:56 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Important. If this is a change from the way the motor has been running you should get it in for check up, ie compression and leak down, borescope. Could be scored cylinder or other issues, none of which are good. I'd do it asap. If the motor has always done this then one bank is burning more oil than the other. Either way this has nothing to do with exhaust tips. Post what is found
Old May 27, 2014 | 09:48 PM
vg247's Avatar
Thanks Gp and everyone,
I'll bring it in and see if there's anything going on for peace of mind. Will provide an update ASAP.
Old May 27, 2014 | 10:08 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Agree!
Old May 28, 2014 | 09:17 AM
lstoker's Avatar
lstoker is infamous around these parts
It may be normal, but a checkout won't hurt anything.
Old May 29, 2014 | 03:45 AM
sneakybear's Avatar
sneakybear is infamous around these parts
I read elsewhere that this is a sign of one bank not being in quite as good nick as the other... was worried when I had similar situation, i.e. worried about scored bores.
However it uses no oil so as a test I turned the car round and parked it the other way on my cambered road for a few weeks and used as normal. The OTHER side started to blacken quicker as a result!
Then I moved house... now the road/garage is flat and no issues.
How did your borescope go?
Old May 29, 2014 | 11:24 AM
vg247's Avatar
Update- took my car into dealer and spoke with the service director: all is normal and they even plugged it in to run diagnosis, nothing came up.
Car is not running any different, not burning oil abnormally, and no fault codes. Peace of mind attained.
Thank you everyone for your input
tropicatango
Jun 8, 2025 01:00 PM
salesguy01
Mar 25, 2019 09:39 AM
turkish1
Nov 11, 2015 09:01 PM
Money2536
Sep 1, 2015 04:56 AM
Because_R4CEC4R
Aug 23, 2015 08:53 PM
