2008 911 4s engine warning at 5000rpm
Old May 31, 2014 | 04:29 PM
Zeno1's Avatar
Zeno1 is infamous around these parts
I get an intermittent engine warning light at 5000 rpm in third gear. It clears after shifting or lowering the rpm. No locked in faults using durametric.
Old Jun 2, 2014 | 08:58 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
is it the dashboard CEL? and is it only at 5k rpm, in 3rd? i.e. what if you hit 6k in 4th etc. i remember test driving an M3 once and i would get some kind of warning and gas would cut off at 5k. i was told by sales rep (whether this is BS, i have no idea) that they set the ECU that way to avoid test drivers joy riding. boy did they know ME well.
but i was thinking that if it's happening in all gears at exactly 5k rpm, it sounds like some kind of limiter.
Old Jun 2, 2014 | 01:37 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
To follow up on what Jiffy said, you may have inadvertently set speed warning in nanny section of pcm. I did this once. May not be rpm which is issue but speed warning. Try going in and removing it.
2lflat4
Nov 18, 2019 05:05 PM
Sayajin
20
Oct 7, 2019 09:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Sales@RSW
Sep 3, 2015 09:34 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
