997 Shifter Cable - Adjustment or Replacement
Old Sep 23, 2014 | 01:56 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Since our cars have shifter cables, I was wondering how many has had their cables adjusted or how many replaced a broken cable.
My old Porsches do require cable adjustments since cables tend to stretch over time. Now, in searching the forum, I did read that someone has adjusted his cable with restored better shifting.
Thanks.
Leaning towards looking at adjusting my cables, or if enough broken cables were out there, I might consider the Numeric product.
Thanks.
Old Sep 23, 2014 | 03:56 PM
kalamazoo's Avatar
kalamazoo is infamous around these parts
If you are post-warranty, replace them with aftermarket. OEM is very weak
Old Sep 23, 2014 | 04:32 PM
cab83_750's Avatar
Have you replaced yours? If so, at what mileage?
For reference, I am at almost 70k and I think I still okay though I want to investigate subtle tightening.
Old Sep 23, 2014 | 07:19 PM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
Adjusting the cables is simple. You just need the green shift alignment tool.
http://www.suncoastparts.com/product/SKU9X7.html
My shift cable snapped at ~45k. The new cables we're much smoother, less friction.
Old Sep 23, 2014 | 07:42 PM
cab83_750's Avatar
Thanks.
When you say new cable, are yuu referring to Porsche factory new, the Numeric or somethin else?
Old Sep 23, 2014 | 07:52 PM
mattyf's Avatar
Originally Posted by cab83_750
Thanks. When you say new cable, are yuu referring to Porsche factory new, the Numeric or somethin else?
Think my previous reply may have gotten lost in the ether.
Porsche cable. I would not upgrade the cable unless you upgraded the shifter as well, since the shifter is the main source of slop.
Old Sep 23, 2014 | 07:57 PM
cab83_750's Avatar
No sweat. My iPhone 4s isn't doing me help also with the new IOS 8 --- spellcheck isn't as great resulting to my grammar and message going into limbo.
Anyone else adjusted or replaced their cable? If so, at what mileage?
Old Sep 23, 2014 | 09:06 PM
dtslmberne's Avatar
dtslmberne is infamous around these parts
Old Sep 24, 2014 | 03:19 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
my cables broke at 22K, stuck in 5th gear, had ittowed
Old Sep 24, 2014 | 06:33 PM
PatrickBateman's Avatar
PatrickBateman is infamous around these parts
I replaced my stock shifter to Porsche SSK and Numeric shift cables @ 34k miles.
My stock units were in good condition, but lacked the notchy feel im accustomed to in previous cars, plus the stock shifter is absolute rubbish ....too long a throw.
Old Sep 27, 2014 | 10:55 AM
cool flash's Avatar
cool flash is infamous around these parts
I just uninstalled my stock shift block because it felt like it had too much slop. Now that it`s out it appears that the block is fine but the shift cables must have lengthened a bit and needed re-adjusted.
Anyway, I am thinking about getting the GT3 shift block (same throw as stock) or the Numeric adjustable one.
Regards,
CF
Old Sep 27, 2014 | 11:21 AM
cab83_750's Avatar
The numeric products are very tempting. The question now though is...
If shifting force stretches the cable and the Numeric cable don't stretch, where would the shifting force go to? I would guess that the next weak link would be where the cable ends at the tranny. I have not seen this end, but I wonder if it's easily and cheaply fixed.
For now, I am leaning toward greasing my box and either adjusting of replacing the cable with a factory one.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
PelicanParts.com
Aug 20, 2015 02:39 PM
TrackOne
Aug 20, 2015 12:56 PM
Aug 19, 2015 06:35 PM
