Gauge Face Problem
Old Sep 24, 2014 | 10:30 PM
mooshwa's Avatar
mooshwa is infamous around these parts
Gauge Face Problem
I'm looking at a 2005 911 (997), and when I test drove it, I noticed the gauges were difficult to read. The numbers (particularly on the speedometer) looked gray/silver and almost ... faded. (almost like they were printed on an old dot-matrix printer).
I've attached an image below.
My question is: Are these cheap aftermarket gauge faces? or is this a factory item that is just ... disappointing? How big of a deal is it, and should I be concerned?
Old Sep 24, 2014 | 10:52 PM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
Seen that before over here.
http://rennlist.com/forums/997-forum...ng-gauges.html
Looks like it's happened to a few people. Also sounds like you can do a gauge face swap later if everything else checks out on the car, but I'd factor that into your pricing.
Old Sep 25, 2014 | 12:21 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
For any gauge refacing, try North Hollywood Speedo. I heard they are pretty good.
No affiliations... Just read enough about them.
Old Sep 25, 2014 | 12:45 AM
gordon9898's Avatar
gordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the rough
There's a brightness adjuster **** between the bottom of the two left gauges, you can see it in the picture you posted.
Old Sep 25, 2014 | 06:59 AM
FlaHeel's Avatar
I just use the digital display for the speedo and focus on the analog tach.
Old Sep 25, 2014 | 07:36 AM
mcurtisal's Avatar
mcurtisal is infamous around these parts
I had the same issue with my 08TT. I ordered the replacement face from FVD and swapped it myself. It really was pretty easy when you follow the instructions.
PV=nRT.
Sep 9, 2022 06:06 PM
Feelgood MD
Mar 24, 2016 09:35 AM
jaehoppa
Oct 22, 2015 09:17 PM
ss2z06
Sep 9, 2015 11:46 AM
zoo
Sep 3, 2015 10:46 AM
