Dectane Tail Lights Brake Light Error? HELP!
Old Oct 4, 2014 | 01:19 PM
socialpro's Avatar
socialpro is a name known to allsocialpro is a name known to allsocialpro is a name known to allsocialpro is a name known to allsocialpro is a name known to allsocialpro is a name known to all
Purchased the dectane lights from a group buy on this forum several weeks back and today I just realized that the BRAKE light shows up as a C shape, and does not go all the way around.
I thought that was ironed out years ago and the current dectanes light up all around. Can someone confirm how the brake light looks on their dectane lights? This is how MINE look (not my car)...is that correct? Or did I get an OLDER pair of dectanes
Old Oct 4, 2014 | 01:23 PM
Ynot's Avatar
Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !
No, that is right, dectanes has always been like this, nothing is wrong with your lights.
Old Oct 4, 2014 | 03:23 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Thanks for the update. My mind is failing me --- I thought they don't light up inward.
It sucks getting old. Lol!
Old Oct 5, 2014 | 10:49 PM
socialpro's Avatar
OK interesting - wonder why the lights were never changed to light up all around as it looks partially 'unfinished' to me. Love everything else about the lights including fit/finish but that brake light pattern just seems pure goofy to me.
Old Oct 6, 2014 | 05:58 AM
no1joey's Avatar
no1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to all
What are these ones then? Scroll down to see the night shot of the brake light, it lights up the whole way around, I would buy these if I could find them, but I am not buying a set of dectanes if they only light up half of the light.
http://rennlist.com/forums/997-forum...installed.html
Old Oct 6, 2014 | 06:22 AM
Dennis C's Avatar
Those are Dectanes, and they only light up part of the light when braking. You can see it in the photos if you look closely. When the headlights are on, the entire light does light up - it's only braking that lights part of the tail light. That's the way they were designed.
Old Oct 6, 2014 | 06:24 AM
no1joey's Avatar
Ah I see.
Old Oct 6, 2014 | 08:33 AM
cab83_750's Avatar
Sorry to beat the horse here.
1. When the headlights are on, the LED's are all on. Correct?
2. When you brake, you have a C-shape light pattern. Correct?
If the headlights are on and you brake, what do you get? If the answer is, "you get a C-shape", can it be wired so that #1 above is always true?
Just asking since I may eventually get these lights, though I tend to favor the full-circle brake light patter. Unfortunately, I would agree that inverted "C-shape" looks goofy; if it were the other way around, it 'might' not be as bad.
GSR Autosport
Aug 26, 2015 05:20 PM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
