Need opinions/help with Cold Air Intake CAI
Old Mar 12, 2015 | 12:04 AM
Miami4me's Avatar
Miami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud of
Originally Posted by epik high
I just did this. Took the cap off a bottle of Castrol oil, turned it upside down and plugged the resonator. Nine sounds more "throaty" below 4k (above 4k the resonator is bypassed anyway for S models)
That's great! A slightly cleaner solution is to get a cap in the plumbing section of Home Depot, and attach it with a small hose clamp, at a cost of about $2. Or you can buy a bundled CAI kit for $200 that does the same thing with a molded cap.
Old Mar 12, 2015 | 09:13 AM
Blue Chip's Avatar
Blue Chip is infamous around these parts
Originally Posted by Miami4me
A much simpler solution is to replace the intake hose and block off the Hemholtz resonator. I found the hose on eBay for $30, and it sounds terrific. I'm sure there's no power increase, but it will increase your smiles per gallon.
On non-s cars you can basically remove the hose from the airbox (the hose on the left) find something to plug it with and replace.
Old Mar 14, 2015 | 08:24 AM
gota911's Avatar
gota911 is infamous around these parts
CAI is really a HAI, as it pulls in Hot air from the engine compartment.
One vendor added a carbon fiber "separator" wing and said that would eliminate the induction of the hot air from the engine compartment!
Old Mar 14, 2015 | 08:31 AM
jhbrennan's Avatar
Vendors also stopped calling it a "cold air intake"...new name is "competition air intake".
Old Mar 14, 2015 | 10:22 AM
noavgdrvr's Avatar
noavgdrvr is infamous around these parts
Now that's an interesting fact...
Old Mar 14, 2015 | 10:57 AM
GS997S's Avatar
GS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond repute
Don't waste your money, and also cause possible warranty issues.
Old Mar 14, 2015 | 01:44 PM
Porschetech3's Avatar
Porschetech3 is infamous around these partsPorschetech3 is infamous around these parts
Short Ram intake with switchable sound symposer and aluminum heat shield . The sound is amazing !!!
Short Ram intake with sound symposer and Lexan heat shield
2007 Carrera S with sound symposer and Short Ram intake . check out website www.bansheestethoscope.com for more pictures and info
Old Mar 14, 2015 | 08:01 PM
noavgdrvr's Avatar
Thank you all for your responses...
I think I will stay with the factory set up. Its seems to be the best bet. For added sound I will look for a good Aftermarket Exhaust.
Old Mar 14, 2015 | 10:23 PM
sober_owl's Avatar
sober_owl is infamous around these parts
maybe add a velocity stack to that last one to increase speed loss by shorter intake pipe!!
Old Mar 14, 2015 | 10:35 PM
Jason-RS's Avatar
Jason-RS is infamous around these parts
Not sure about performance, but GruppeM provides the best sound track imo
Old Mar 14, 2015 | 10:36 PM
Jason-RS's Avatar
Mostly due to the carbon intake and ti exhaust pairing
danyoP4S
Sep 30, 2021 05:06 AM
Rguy
Apr 12, 2020 11:11 PM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
Rockinc1
Sep 30, 2015 06:44 PM
