Pressure plate problem
Old Mar 3, 2015 | 12:04 AM
Khaim3's Avatar
Khaim3 is infamous around these parts
Started my car on Sunday morning. I heard a little pop after depressing the clutch. Car started fine but couldn't get into any gear.
I searched and believed that my pressure plate is bad. I can shift into gears when engine turned off.
I called Alex at Sharkwerk and he quoted $800 for clutch and pressure plate kit and $1k for labor.
What should they look for while the transmission if off the car?
Thank you,
Khai
2007 C2s
28,xxx miles
CPO Expired 1-31-2015
Old Mar 3, 2015 | 12:18 AM
PatrickBateman's Avatar
PatrickBateman is infamous around these parts
RMS...(rear main seal). if you have not changed your gear oil... have them do that at the same time.
Consider plug replacement ? I swapped plugs/coils at 40K on my rig.
Brake flush every 2 years.
power steering fluid...dirty? change it.
Are you the orig owner? clutch at 27k, huh? strange.
EDIT! I just saw your car just ran out of cpo 30 days ago... have you tried your local dealer, and see if big brother will goodwill you a new clutch yet? that's where I would go first. good luck!!
Old Mar 3, 2015 | 12:26 AM
Khaim3's Avatar
Bought the car 2 years ago with 24,000 miles.
Dealer replaced all spark plug 2 years ago.
I don't think CPO COVER clutch or pressure plate right? And it's more than 30 days after expiration date
Old Mar 3, 2015 | 02:38 PM
Hey, all you can do is ask, right? doesn't hurt.
I had a previous 911 clutch replaced once on the house. car had stupid low miles, warranty was expired, but it was a goodwill.
Give that a shot first. so, you've only driven the car 2k miles in 2 years?
PV=nRT.
Sep 9, 2022 06:06 PM
Feelgood MD
Mar 24, 2016 09:35 AM
Rockinc1
Sep 30, 2015 06:44 PM
su_maverick
Sep 8, 2015 11:12 AM
