greenish brake fluid
Old Apr 24, 2015 | 09:57 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
just flushed brake fluid and it was a greenish color. 06 29K, dealer did 2.5 yrs ago, have paperwork and its on carfax. 12K since done at P dealer.
Flushed thoroughly 2X with ATE and is flowing clear now. Old fluid was clear in master cylinder but greenish coming out. Any theories+
Old Apr 24, 2015 | 10:29 AM
yvesvidal's Avatar
yvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of light
Easy. Green is the combination of Blue and Yellow. Usually, when you change the Brake fluid, you can alternate between the BLUE ATF and the YELLOW ATF. You can never get rid of the Blue one completely, and so you end up with a greenish color when you fill up your circuit with Yellow brake fluid.
Yves
Old Apr 24, 2015 | 04:20 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Yves
+1
Though it's interesting that the dealer alternate colors. I thought most dealers would use regular Porsche brake fluid. ????
Old Apr 24, 2015 | 07:11 PM
barncobob's Avatar
I dunno, old fluid was clearish in master cylinder, I turkey bastered it out, replaced with new fluid, never saw any blue anywhere.Im assuming the P dealer would use factory fluid???im stumped..
Old Apr 24, 2015 | 08:27 PM
cab83_750's Avatar
For your peace of mind, my theory would be: they probably ran out of colored fluid at the tail end of the flush and they just started using regular non-colored fluid.
From what I understand, copper could change the color of the fluid though I do not know if we have copper in our lines. Assuming you have a brake bleeder, just flush one corner after 5k miles or so.
Old Apr 25, 2015 | 08:12 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
I've seen fluid in the calipers turn darker colors due to heat. When flushing only the first bit coming out is a different color than the reset. It's more pronounced in the front. Perhaps that's what you saw?
Old Apr 25, 2015 | 09:24 AM
barncobob's Avatar
no, it was rears, greenish but not solid green, like a flocuette material..Can algae be in brake fluid....I got about a 1/2 litre amt out of 2 rears before turning clear.
Old Apr 25, 2015 | 04:37 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
I was actually thinking you've got algae in the fluid but that usually happens at point of water contamination, like the fluid reservoir of the master. Possibly water ingress when cleaning the frunk or something..
Rguy
Apr 12, 2020 11:11 PM
Feelgood MD
Mar 24, 2016 09:35 AM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
