brake noise
Old Nov 2, 2005 | 08:32 PM
doc2s's Avatar
doc2s is infamous around these parts
brake noise
my 997S brakes squeel/squeek while driving but noise goes away when i press the brake pedal. the dealer checked it and says its normal! the car has 6600 miles and the problem started around 4000 miles.
any suggestions or experience with this problem?
many thanks
Old Nov 2, 2005 | 08:42 PM
Le Chef's Avatar
Le Chef is infamous around these parts
Mine don't squeal at all, ever. Sounds like you need to talk to a different dealer.
Old Nov 2, 2005 | 09:00 PM
superfans's Avatar
superfans is infamous around these parts
Do you feel the brake pedal is a bit sticky when pressed slowly?
Old Nov 2, 2005 | 09:34 PM
gdctus997's Avatar
gdctus997 is infamous around these parts
On most cars that is a sign that the brake pads are worn and need to be replaced. Your miles are very low, however. Have you been driving at a track, or like your on a track?
Old Nov 3, 2005 | 06:35 AM
Doctor K's Avatar
Doctor K is infamous around these parts
I would immediately take the car somewhere else for an evaluation of your braking system! Brakes should not make a noise when driving. Rotor are expensive, calipers too.
Old Nov 3, 2005 | 07:21 PM
doc2s's Avatar
edal feels fine.
Old Nov 3, 2005 | 07:23 PM
doc2s's Avatar
i did track the car several times. the dealer checked the pads and rotors and said every thing looks fine. don't know what else to look for.
Old Nov 3, 2005 | 11:10 PM
Vik's Avatar
Vik
Vik has a spectacular aura aboutVik has a spectacular aura about
He said they squeal WHILE driving NOT when braking. You might have a loose caliper pin. Def take it to another dealer.
Old Nov 4, 2005 | 07:00 PM
superfans's Avatar
How long does it take to "bed-in" the brakes? 200-300 miles? Before the brakes are fully "bed-in", will they sometimes create slight creaking noises? If there are streaks on the surface of the rear brake discs, could that be dirt/dusts or something is wrong? Thanks.
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
