2009 Carrera. Time to replace the shocks and I need help.
Yes worn shocks would result in the rear end being bouncy - try pushing up and down on passenger rear and if it bounces without immediately settling down, that is worn shocks.
Your symptom does not sound like worn shocks (they should not be worn as previously posted, given your mileage) but perhaps a broken or loose shock tower on the passenger side - did you hit a big pot hole recently? Is the passenger rear Wheel damaged at all (would indicate a hard hit), maybe engine mounts as others suggested. I'd take it to an Indy ASAP. Probably don't need to replace all 4 shocks is the good news....
Discovered this quarter panel was repainted at some point. I will take the shock out tomorrow and inspect the suspension.
I am planning on getting the car checked before the end of the week, I have ordered the rear shocks just in case they are needed at the time of the check up.
I will update the post as soon as I get the issue resolved.
