Please take a few secs to answer question re: your water pump
Old Aug 6, 2015 | 04:09 PM
GBG's Avatar
GBG
GBG is a jewel in the roughGBG is a jewel in the roughGBG is a jewel in the rough
Thanks guys to those who replied. We don't yet have enough of a sample size to draw any reliable conclusions, but so far the numbers are below. It would be interesting if we received many more responses and nearly all the failures occurred at 40k miles or below.
-- 5 Water pump failures at the following mileages:
28k, 20k, 40k, 23k, 75k
-- 6 Original pumps were still healthy at the following mileages:
24k, 31k, 38k, 57k, 67k, 80k
-- 2 peanut gallery remarks about topic being beaten to death. I've seen many qualitative posts on water pump failures, but none were particularly quantitative. It'd be interesting to see the data on pump failures.
Old Aug 6, 2015 | 05:10 PM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
IMHO mileage is important but you have to also consider the age of the water pump, the environment of the car (i.e heat, cold temp, aridity, etc).. as well as how often and how hard u drive.
In other words, there are too many variables to consider... and u cannot come to simple conclusion based on just the mileage.
fwiw
2007 C2S manual: replaced the WP at 60000 miles (8 years old) as a preventative maintenance in Jun 2015
Old Aug 6, 2015 | 05:15 PM
ehoffarch's Avatar
ehoffarch is infamous around these parts
Failed at 60,000. Pulley shaft sheared off while driving home from a long road trip. Covered by extended warranty.
Old Aug 6, 2015 | 06:32 PM
mshanler's Avatar
mshanler has a spectacular aura aboutmshanler has a spectacular aura aboutmshanler has a spectacular aura about
Mine failed at ~ 40,000 miles when about 8 yrs old. Cracked plastic reservoir case.
Old Aug 6, 2015 | 07:07 PM
sandwedge's Avatar
sandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud of
-09 C4S, failure at 41,000 miles. Replaced under extended warranty. Around $1,300 as i recall it.
Old Aug 7, 2015 | 08:17 PM
GBG's Avatar
GBG
I'm sure you're right!
turbotuner20v
Sep 11, 2015 12:02 PM
LiquidElephant
Aug 27, 2015 06:17 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
