Need a little help?!? License Plate Fuse
Old Sep 18, 2015 | 04:14 PM
Motams's Avatar
Motams is infamous around these parts
Hi Everyone,
I made the idiotic decision to change my license plate bulbs to Led. One worked and upon installing the second they both stopped working. 2010 C4S
I believe it is a fuse issue, however for the life of me I cannot figure out which fuse it is on the panel?!? I have read it is "Fuse 11" but it only goes up to 10 for rows ABCD can someone please help? Need to drive the car tonight :/
Frustrated In Chicago
Old Sep 18, 2015 | 05:46 PM
jhbrennan's Avatar
Originally Posted by Motams
Hi Everyone,
Why do you think it's a fuse? Have you tried to re-install your OEM bulbs - that would tell you pretty quick if the lights are getting power or not. Also, LED's are polarity sensitive - you might just have to flip the bulbs.
Old Sep 18, 2015 | 05:52 PM
MkC2S's Avatar
+1, re-install your oem bulbs if it works or not
Old Sep 18, 2015 | 06:59 PM
Motams's Avatar
Hi guys!
Driver side bulb was on, put it back on, working. Remove passenger side swap, put back. Both are out, put in original bulb and nothing.
Appreciate the help!!
KC
Old Sep 18, 2015 | 11:50 PM
MkC2S's Avatar
found a few threads that may help somewhat. G/L
https://www.6speedonline.com/forums/...d-problem.html
http://rennlist.com/forums/997-forum...light-led.html
Old Sep 28, 2015 | 07:41 AM
Motams's Avatar
Hi All,
Just to follow up, thanks for your help much appreciated.
I'll put on my "dunce cap" I should have known better. I had an hour and thought 4 Torx and 2 bulbs this should take literally 10 minutes with patience. NOPE
I ended up putting the OEM back the next day and it worked. I just have a hard time paying Suncoast $50 for LED license plate lights. Looks like there is no other option tho :/ frustrating to say the least. Benz was the same way!
adnanm3
Oct 25, 2016 08:38 AM
ECS Tuning - BMW
Oct 1, 2015 01:35 PM
ECS Tuning - BMW
Oct 1, 2015 01:29 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
