Bleeding brakes.
Old Oct 4, 2015 | 10:35 AM
  #31
no1joey's Avatar
no1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to all
Cheers!
Less than half a litre is not a lot. Do you have to put through that much for each caliper or all 4?
I just can't picture how that works, you have to bleed 2 nipples on each 4 calipers, and the total is less than half a litre? How does that flush the whole system? If you know what im trying to say, is each calipers brake fluid line separate or connected?
Old Oct 4, 2015 | 11:23 AM
  #32
RBarbieri's Avatar
RBarbieri is infamous around these parts
If you’re going to flush the system remove the fluid from the master cylinder into your catch bottle with something like a turkey baster and mark the level. That way you can always determine when you need to refill the master cylinder.
BauerR
Jun 25, 2017 11:53 PM
jabed92694
Apr 3, 2016 11:31 AM
jsedacca8
Feb 23, 2016 09:43 AM
smac
Sep 26, 2015 05:55 PM
nb6179505
Sep 21, 2015 09:08 AM
