Wheel Setup 19 Front 20 Rear
Old Jan 19, 2016 | 08:47 PM
Szymon Kowalczyk's Avatar
Szymon Kowalczyk is infamous around these parts
I'm thinking of getting new wheels and just wondering if anyone is running the setup of 20x11 Rear and 19x9.5/8.5 Front. Please post pictures.
Old Jan 20, 2016 | 12:25 PM
yvesvidal's Avatar
yvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of light
Just make sure you do not have a C4 when doing that.
Yves
Old Jan 20, 2016 | 02:20 PM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Yves
Shouldn't matter for the AWD system. Outside rolling diameter would be the same front to rear. There's just less rubber between the 20" wheel and the road than the 19" wheel and the road. The tires would be sized to keep outside rolling diameters very close.
OP - wouldn't consider it myself but I'm curious in how it would look. If you get photos be sure to post them up. I haven't really thought through handling issues though, if any.
Old Jan 20, 2016 | 03:37 PM
StormRune's Avatar
StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !
I used willtheyfit.com to check this. As semicycler points out you would also need to change the side profile to keep the overall diameter very close to the same. You may have be aware of this but lets talk it through just to be safe.
Using that calculator and only changing the wheel size and the profile, a 20 inch 295 tire would require a 25 profile to keep the rolling circumference difference down to 0.63% which should be fine. It would be quite noticeable since that translates to a sidewall height of 52mm being reduced to 37mm... and noticeable not only in visual terms but in ride quality terms as well. The difference between the rear and front sidewall heights isn't all that bad though since the fronts are 35 profile tires but are narrower; so they end up with a 41mm sidewall height. So maybe 37mm in the rear isn't so bad after all.
The 991 models can get away with 20" wheels and narrower sidewalls since their suspension was designed for it. For our cars I would think it would mean a very noticeable ride quality change. Others that have 20" wheels could speak to this better though. So overall, yeah it is doable. Sorry, I didn't really help with pictures.
Old Jan 20, 2016 | 07:18 PM
gonz996's Avatar
gonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond repute
I ran 20"s on my prior 997 and I could feel every joint on the road. Just saying.
Old Jan 23, 2016 | 03:47 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
I hate too disagree with you "gonz". I run 20"s and with PASM and I certainly don't feel every joint in the road! It could be a Texas thing I guess?
Old Jan 23, 2016 | 08:51 PM
mickfluff's Avatar
mickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant future
What he said. Either u put in cheap 20s or were running cheap worn tires. I have had 19s and 20s and virtually no difference. I just did 20s and went with a very well made 20 lite weight and new tires and the ride is fantastic.
Old Jan 23, 2016 | 09:52 PM
gonz996's Avatar
That's fine, fella. I was running new wheels and new rubber. That was on my prior 997. Before I sold it, I went back to 19". You can't deny the lower sidewalk doesn't absorb more imperfections in the road. Say what you want, it's true.
Old Jan 24, 2016 | 11:21 AM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
Agreed - I just went from 18s to 19s and if anyone could not tell the difference in ride, they just aren't sensitive to that sort of thing or they have fantastic roads. I imagine 20s would be even more pronounced. Although I think the decision to go with 20s is not about ride or performance; it's aesthetics - some like the look - I think it pushes the 997's design a little too much.
jtorrebl
Cayenne 958
30
Nov 11, 2023 12:22 PM
SethW
Wheels/Tires
Jan 29, 2016 02:12 PM
WheelB
American Muscle
Dec 9, 2015 01:32 PM
WheelB
BMW //M
Dec 9, 2015 10:50 AM
