Aw ****. Water pump took a dump....need help.
Old Mar 22, 2016 | 04:09 PM
ALEV8's Avatar
ALEV8 is infamous around these parts
Was in the car s long time today. Car did not overheat and I stopped eventually to grab a coffee--and came out to the car dripping behind the drivers rear tire. The expansion tank is still 95+ percent full. I'm about a mile from home and wondering if I can safely drive the car home. Not wanting to risk it but there's just a steady drip coming from the water pump. Perhaps 16oz on the pavement....All signs point to no, but it's not a catastrophic leak.....
Old Mar 22, 2016 | 04:34 PM
ALEV8's Avatar
Well F it. Not overheating and it's just a drip. Got home in 5 min and I have a can under it. Needle never got past 175f. Question is do I go for a pump, seal, serpentine belt and hoses or what? No warning lights on either as to coolant loss.
Old Mar 22, 2016 | 05:54 PM
RaidersR1's Avatar
RaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of light
Well if you are going in there might as well do it all. How many miles? Is it time for the other stuff?
Old Mar 22, 2016 | 06:04 PM
ALEV8's Avatar
Yes 104k, might as well agreed. Question is has anyone tried the other pumps offered by Pelican? 1-200$ versus almost Suncoast at 319$.
Old Mar 22, 2016 | 07:09 PM
RaidersR1's Avatar
I asked the same question. There are some cheaper options and it's not Porsche branded. Do a search via Water Pump. You will find it.
Old Mar 22, 2016 | 09:37 PM
Macster's Avatar
What I have come across is while some have opted for non-Porsche water pumps they often do not last very long. You got over 100K miles out the stock pump. Why risk getting something that might not last as long or worse fails in a much worse way?
Old Mar 22, 2016 | 10:14 PM
ALEV8's Avatar
All in
Hope I didn't forget anything....
Old Mar 23, 2016 | 03:56 AM
Jagman1's Avatar
Jagman1 is infamous around these parts
You won't regret going with the Porsche pump. I had a water pump go out on my Cayenne at 88K miles, replaced it with a Laso pump (an OEM supplier). That pump failed at 98K miles. Running on a Porsche pump now that has 35K miles on it with no issues.
Only other items to consider might be belt tensioner, and idler pulleys. Do make sure you give those a thorough inspection if you decide not to replace.
Old Mar 23, 2016 | 08:15 AM
yvesvidal's Avatar
yvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of light
For having done that job this past weekend, I would recommend the following:
- Get a Porsche genuine pump. These pumps have plastic impellers that will not destroy your engine if something goes wrong. Most aftermarket parts have metal blades that may cause some damages inside your engines. Porsche pumps are around $340 currently. Get the gasket, too.
- Change the thermostat and gasket. About $64 + 8.
- Change some hoses if you feel inclined to.
- Change serpentine belt ($54)
- Check carefully pulleys.
- Use an airlift ($130 at amazon) 550000 to create vacuum and insert the coolant.
Yves
I'll have a how to do it, in a few days, but there are plenty of info on the forums.
Yves
Old Mar 23, 2016 | 12:28 PM
ALEV8's Avatar
I put a catch can under the car yesterday when I got home, and it maybe dripped 2-3 tablespoons of coolant overnight. Maybe a depressurization keeps the system from leaking? Dunno.
I forgot a tensioner and hoses Yves. I will for sure order hoses. Look at them!
Old Mar 23, 2016 | 01:22 PM
ALEV8's Avatar
Ordered a tensioner pulley. Might as well and mine was noisy until I removed my exhaust for a while. Reinstalled exhaust and it had disappeared/ warmer weather alleviated it? Gotta find hoses next.
Old Mar 26, 2016 | 02:56 PM
ALEV8's Avatar
Oddly that three part pump was HALF price at ECS. Ordered the rest from Sonnen.
mrtexasfreedom
993
Mar 14, 2016 03:17 PM
Gene G
Mar 12, 2016 02:05 PM
embdenb
Mar 9, 2016 10:04 AM
cdiehl
Mar 2, 2016 01:42 PM
Britus05
Feb 28, 2016 08:24 AM
