tap power line when engine running
Old Apr 20, 2016 | 11:02 PM
koenbro's Avatar
koenbro is infamous around these parts
**EDIT** The term I was looking for is "switched power". Sorry didn't know this when I posted originally and now I can't edit the thread title.
I have installed a Blackvue dashcam and the Power Magic Pro adapter that is in the center console needs two power inputs: one that is permanently on (got that from cig lighter in passenger footwell) and a second one that is live only when the engine is on. Where can I get this second power input? Does the head unit loom have one such line I could tap into? Car is a 2007 C4s w/Tip and PCM 2.1 w/Bose. Thanks.
Old Apr 21, 2016 | 07:33 AM
markj's Avatar
markj is a jewel in the roughmarkj is a jewel in the roughmarkj is a jewel in the roughmarkj is a jewel in the rough
Not sure about the 2007, but on my 2011 C4s the head unit loom would not work because of some type of electrical feature on these cars, had to remove A-pillar and run wire all the way down to fuse box in footwell. I was wiring an escort.
Old Apr 21, 2016 | 03:15 PM
Flying Cat's Avatar
Flying Cat is infamous around these partsFlying Cat is infamous around these parts
Yes, there is switched power source at unit with lights & garage door opener on ceiling. I tapped switched power source to connect my radar detector.
If you search for switched power radar detector you should find posts with details and pictures.
Old Apr 23, 2016 | 04:26 PM
koenbro's Avatar
Yes, the mirror light is switched but I need switched power specifically behind the radio head unit. I found that the cig lighter and the HU are permanently on. I might be forced to tap into the fuse box, but the Autozone Add-a-fuse seems too tall and doesn't let me close the fuse box cover.
Old Apr 23, 2016 | 04:48 PM
StormRune's Avatar
StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !
It is not too tall, you can easily close the cover. It is also a cleanly reversible, it is 100% known to work reliably, and there's no risk of cutting a factory wiring harness wire when trying to splice in. You can see photos of it in my fusebox in my post to the thread you started over on Rennlist.
White991S
Jun 11, 2016 05:18 PM
han_job
Merchandise For Sale / Wanted
May 10, 2016 12:09 PM
bobolouie
Apr 27, 2016 08:38 AM
ECS Tuning - BMW
Apr 19, 2016 08:27 AM
Second Childhoo
Apr 15, 2016 09:01 AM
