Strange metallic noise when revving
Old May 4, 2016 | 11:48 AM
tc65's Avatar
tc65 is infamous around these parts
Hi,
I had a waterpump failure and had it replaced by my mecanic. (indy)
When I got home I heard a strange metallic sound in the engine bay or from the exhausts when revving. I didn't hear it with the windows up. But in my garage you can clearly hear something doesn't sound good.
Any idea what this could be? And is it still safe to drive?
My mecanic is on holiday until Monday...
Thanks,
Tony
Old May 4, 2016 | 08:23 PM
EMC2's Avatar
EMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud ofEMC2 has much to be proud of
Originally Posted by tc65
Hi, I had a waterpump failure and had it replaced by my mecanic. (indy) When I got home I heard a strange metallic sound in the engine bay or from the exhausts when revving. I didn't hear it with the windows up. But in my garage you can clearly hear something doesn't sound good. Any idea what this could be? And is it still safe to drive? My mecanic is on holiday until Monday... Video Link: https://youtu.be/wYUbd41KvJ0 Thanks, Tony
I couldn't hear the metallic noise in your clip, but youtube sound clips are not very reliable for diagnosis in most cases.
To start with I would take a rubber mallet and knock the exhaust pipes and mufflers in different places to ensure you're not hearing a rattle from something that wasn't put back together correctly on the exhaust system.
If nothing there, then i would be cautious and take it back for inspection.
Good luck.
Old May 5, 2016 | 04:21 AM
tc65's Avatar
Also the next morning cold start was very loud! like a rattle from the engine amplified by the exhausts...
I was nog giving gas. Just idle start. This went away after about 10 seconds
Old May 6, 2016 | 12:40 PM
lurchphil's Avatar
lurchphil is infamous around these parts
I would take a look at the engine mounts and the exhaust system. If they were loosened or removed to install the water pump, they might have been overlooked on reinstall.
Old May 6, 2016 | 06:46 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Nobody can or should tell you it is ok to drive based on clip or description. I would start by having someone loosen and remove the belt and start the engine. If it is pulley or pump related you will know right away. If like me you don't have the aptitude or tools and cannot definitely identify this as an exhaust noise/rattle call the tech and have him take care of it. I assume you paid him with good money, right?
Jako
Sep 6, 2016 09:36 AM
Gene G
Apr 11, 2016 10:54 PM
Hocdoc527
Apr 11, 2016 07:48 AM
Jeff_335i
Apr 8, 2016 09:22 PM
