oil leak advise, help, short term loan?
Old May 29, 2016 | 08:40 AM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
My turn in the barrel. Wed night added 1/2 qt in driveway as earlier reading was down 2 bars. Car not run but in am fresh oil on ground just left of centerline of car on drivers side under rear of motor from area behind sump. Thought it was a spill but after driving car losing oil at faster rate, pool under car, guesstimate 1/2 qt in 2 days. Leak continues during and after driving.
Bottom of motor is dry. No oil on top around or under filler tube. Car runs well. No lights bells whistles or smoke.
As I drive I notice an unusual small deviation in temp gauge reading, slow oscillation up/down maybe 3-5 degree displacement. Not noticed this before. Temps appear normal. Very hot here In NY.
Is there an external connection to/from the OT gauge that may be leaking. Also note the oil pressure gauge is due replacement reading high but I have not gotten to that yet. Thinking but not sure that is unrelated. It would appear oil is pooling, leaking from top or side as there is no evidence of a leak I can see on bottom. The oil is clean and clear. 2006 S 43K miles.
As always I am appreciative of the Boards input. Ideas anyone?
Old May 29, 2016 | 12:46 PM
Gpjli's Avatar
Looking at this again I see that what I thought was oil is a red liquid, and coolant level is below minimum. Water pump related. I guess that's better and makes more sense in view of the location. Long weekend w/o a car. Could be worse. Cheers.
Old Oct 4, 2022 | 01:03 AM
Jimatunes's Avatar
Jimatunes is infamous around these parts
I recommend you to contact a good car mechanic. Oil leakage is serious.
Old Oct 7, 2022 | 09:37 AM
GT3 Chuck's Avatar
Administrator
Six year old thread guys
fastrx7man
Nov 17, 2017 06:39 PM
bilba
May 28, 2012 08:39 AM
hummerchine
Dec 15, 2011 08:29 AM
iornman86
Dec 20, 2007 04:50 PM
