Engine whistles when hot...
Old Sep 8, 2016 | 06:45 PM
cairo94507's Avatar
cairo94507 is a jewel in the roughcairo94507 is a jewel in the roughcairo94507 is a jewel in the rough
OK so my wife said her car ('10 C4S) was "whistling" when it was hot. She came home and sure enough, the engine was whistling.
Took it to Porsche of Livermore and they diagnosed it as a water pump getting ready to fail. Car has 36K miles on it. So now it gets a new water pump and coolant flush. Good to go. I should have it back tomorrow afternoon. Glad it whistled before it failed completely.
Old Sep 8, 2016 | 08:21 PM
MIKCOB's Avatar
MIKCOB is infamous around these parts
How much is the stealer charging you for the job out the door?
Old Sep 9, 2016 | 06:55 AM
cairo94507's Avatar
I have a Fidelity Platinum warranty that is covering it. When I pick the car up I will find out what it otherwise would have been.
Old Sep 9, 2016 | 10:47 AM
MIKCOB's Avatar
Keep us posted. Thanks!
Old Sep 9, 2016 | 11:40 PM
PatrickBateman's Avatar
PatrickBateman is infamous around these parts
Now I don't feel so bad doing mine as preventative maintenance at 38K.
I did mine myself and it took around 2.5 hours , and did all new coil packs and plugs at the same time.
I used genuine Porsche parts, and the Plastic impeller on the pump.
Old Sep 11, 2016 | 01:04 AM
Racetwin2's Avatar
Racetwin2 is infamous around these parts
I had the same. Sounded almost mechanical.
I P ut some belt dressing on and it went quiet. By the noise I had I also thought it was the water pump or idle pulleys etc. But this happened in the spring and the engine still runs fine and quiet.
I know it's already in workshop but for others it is good to check belt first. On the other hand the pump needs replacement sooner or later anyhow.
Old Sep 11, 2016 | 09:08 PM
cairo94507's Avatar
Got the car back, new pump and coolant flush. Cost me my $100 deductible. They billed Fidelity almost $1,200 for the water pump. Holy cow! That extended warranty was a good move maybe.
E-Gear
Aug 27, 2016 08:22 AM
ExSF
Bentley
Aug 23, 2016 04:41 PM
WEEED
993
Aug 21, 2016 07:13 AM
Aug 15, 2016 01:58 PM
