Convertible top leaking and can barely move....
Old Oct 10, 2016 | 08:46 AM
Quattshot's Avatar
Quattshot is infamous around these parts
Convertible top issue....
Hello all!
So I purchased a clean low mileage 997 Carrera Cab a few months back. All has been great but recently I noticed some oil stains on the garage floor in two different spots, one stain on each side of the car. I then went to put top down and it struggled heavily! It BARELY made it closed. I guess my questions are...Does anyone have tips or DIY on fixing this or rebuilding the hydrolics in the most cost effective ways? Also, what is the typical cost to replace parts needed if I decide to go to a shop? Thanks for the advice in advance.
Old Oct 10, 2016 | 06:52 PM
PoundCake's Avatar
PoundCake is infamous around these parts
No issues here, all works good. Good luck!
Old Oct 12, 2016 | 11:33 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Originally Posted by Quattshot
Hello all!
Not heard this problem before. I'd ask around for reputable indie in your area and see what they suggest.
Old Oct 13, 2016 | 05:08 AM
Quattshot's Avatar
From what I hear, the convertible top eventually leaking oil is a pretty common occurrence. I'm just not familiar with any options that's might be available such as rebuilding the hydrologic reservoir or buy brand new and finally cost of either option.
Old Oct 13, 2016 | 07:33 AM
FlaHeel's Avatar
I have a 08 cab and I had the exact same symptoms. I would guess that it is what they call "ramps." Those are the two hydraulic pumps on either side that raise and lower the top. Mine went out about 8 months ago and it was close to $4k at my dealer. I caught mine early and the only oil I had was in the top storage area. Good luck.
Old Oct 13, 2016 | 01:45 PM
North Shore 911's Avatar
North Shore 911 is infamous around these partsNorth Shore 911 is infamous around these parts
My 2010 C4S Cab has been rock solid, but now I'm wondering if there is a way to check fluid levels in the hydraulic pumps? I did have a Jag XK8 convertible many moons ago that had a regular, but small, leak in the pump. As long as I kept the fluid topped up, it worked fine
Good luck with the fix, and please keep us updated on troubleshooting and the eventual fix (plus any preventative maintenance that we should be doing, if any).
Old Oct 13, 2016 | 06:50 PM
Quattshot's Avatar
Thx man. I called a well known indie shop today called Foreign Affairs and they quoted me $1,100 out the door . .Yes the units are rebuilt and not new but the shop is offering a 3 year warranty. Many folks have let FA do this repair with great results.
Old Oct 13, 2016 | 06:58 PM
Quattshot's Avatar
From what others are saying, it appears when you have leaking , the reservoirs are past saving therefore refilling with oil is useless. If I'm wrong someone please correct me. I had oil on my garage floor on both sides of the car, so I knew both units were shot. The good news is that I'm being told that once fixed, it'll be years till this happens again.
Old Oct 17, 2016 | 09:20 AM
FlaHeel's Avatar
Good deal, and with 3 year warranty....you bet!
Old Oct 18, 2016 | 04:23 PM
Worldisyourz's Avatar
Worldisyourz is infamous around these parts
Same issue here when I bought my 40k mile 07 C2S. Brought it home and noticed a leak around the rear tire. Took it in and sure enough one of the hydraulic cylinders that controls the top was leaking. $1800 parts and labor later, all good.
Old Oct 18, 2016 | 09:16 PM
gonz996's Avatar
gonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond repute
Buy a can of silicone lubricant and spray it on a rag. Lightly apply it to all the touch points including the very top edge of your windows. I had the same issue on my E46 M3 Vert and this cured the problem. I'm not sure if that's related, but it can't hurt. Good luck.
Old Dec 5, 2019 | 02:13 PM
rolfsb's Avatar
rolfsb is infamous around these parts
Quattshot,
Did you ever pull the trigger with Foreign Affairs to fix the leaky parts for the convertible top ? I have the exact same issue and want to know if they did a good job at a reasonable price. Thanks.
MrVette
Bentley
15
Apr 3, 2017 10:26 AM
Duff0000
Oct 25, 2016 11:26 PM
alexhuth
Aug 31, 2016 12:28 PM
Wasfi Khundaqji
Aug 21, 2016 03:14 AM
montreal911
Aug 10, 2016 07:42 PM
