Bluetooth streaming using Android phone
Old Dec 2, 2016 | 03:57 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Been using the viseo/iPhone ever since I can remember for Bluetooth music streamin but now moving to an android phone. Anyone with experience with the best connection device. I read that the viseo also works with android to stream music but the tracks are not showed and controls are on the phone. Hoping for same functionality as the viseo/iPhone combination...hope somebody is running a link like this.
Old Dec 2, 2016 | 07:24 PM
Viseo works but
Viseo works Waze, Spotify etc with Android. But, the screen of the pcm does not show any of the tracks and options like when using the iPhone
Old Dec 6, 2016 | 01:31 PM
simtiaz's Avatar
simtiaz has a spectacular aura aboutsimtiaz has a spectacular aura about
I am using iSimple in mine with no issues, it displays stations/artis/song info on the pcm screen and calls are clear.
http://isimple.com/catalog/install/ISFM2351
Old Dec 7, 2016 | 05:41 AM
Wow. Anybody else have the same experience with the I simple?
Old Dec 7, 2016 | 05:44 AM
It says transit uses the fm station. Do you experience loss in audio quality?
Old Dec 9, 2016 | 04:15 PM
myw's Avatar
myw
myw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to behold
no audio quality loss - while its an fm transmitter, the unit actually physically cuts into the FM antenna via an antenna adapter. hence forth no signal change/loss whenever your engine is on , driving/moving, regardless of where you are.
i've used the standard fm transmitters in the past and they sounded ok (provided the engine wasn't on and the car wasn't driving around), otherwise it would sound exactly what you are imaging re fm transmitter quality - you will be surprised with the tranzit blu hf.
Old Dec 10, 2016 | 08:56 AM
jchapura's Avatar
jchapura has a spectacular aura aboutjchapura has a spectacular aura about
I too use the "iSimple Hands-Free Calling and Music Streaming Kit with Control Button for Smartphones". Sends its signal through the antenna jack; you can select an "unused" area on the FM spectrum over which to send the signal. Sound quality is good to very good. The only issue I've had is, even though you can select the FM frequency, if you leave the Bluetooth on, on the smartphone, and tune to your favorite FM radio station that is relatively weak, the sound quality of the radio station is diminished when compared to having Bluetooth off on the smartphone.
Old Dec 12, 2016 | 12:11 PM
Derek Zoolander's Avatar
Derek Zoolander is infamous around these parts
I have the TranzitBlu HF bluetooth kit in my 2008 997 C2S. Sound quality is very good. Only complaint is that I get some interference/noise through the radio when audio is not playing.
Old Dec 15, 2016 | 10:30 PM
myw's Avatar
myw
what about turning off the bluetooth on the phone off and making sure that the traznit blu is also off (non pairing mode). when i do both those things its back to completely oem sounding fm/am levels.
Old Dec 22, 2016 | 03:35 PM
I'm saying that when I have it connected, and there's no music playing, I get interference/noise.
Old Dec 23, 2016 | 07:19 AM
Domer911's Avatar
Domer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond repute
no hijack here, but can we rewind about 5 years for me, please?
I have a 2011, and an android device, how can I stream music?
