TPMS issue
Old Dec 19, 2018 | 02:32 PM
Jonhunt's Avatar
Jonhunt is infamous around these parts
TPMS issue
I'm wondering if my problem is low batteries in the sensors. I'm getting what appear to be accurate readings, but the orange warning light is on. Then at other times I don't have any readings. See the attached photos as examples.
Old Dec 19, 2018 | 05:49 PM
Nastee_C4S's Avatar
Nastee_C4S is infamous around these parts
I know mine needed reprogrammed/or calibrated. Once completed I think I drove 10-15minutes and everything was normal again no more warning lights.
Old Dec 19, 2018 | 06:15 PM
PoundCake's Avatar
PoundCake is infamous around these parts
You may have a nail in your tire.......once this is fixed, all good!
Old Dec 20, 2018 | 06:00 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
Sounds like batteries. Will work when you first get in and start the car, but then the weak battery stops communicating and you get the error. My Infiniti exhibited the exact same behavior when the batteries were dying.
Old Dec 20, 2018 | 07:39 AM
Jonhunt's Avatar
Thanks. I assumed it was a battery issue. They have been in there for about five years.
Old Dec 23, 2018 | 09:35 AM
Freeze's Avatar
Freeze is infamous around these parts
Had the same issue recently. Got these: https://tpms247.com/collections/2011-porsche-911
Had them swapped out with the originals while having some curb rash repaired. Once installed, go through usual reset procedure, they'll be up and working after a few miles. A lot less than you would pay for OEM, and they work great.
rossyl
Sep 28, 2016 07:54 PM
HOiYA
Cayenne
Dec 10, 2014 02:26 PM
steven1
Oct 6, 2010 12:12 AM
JEllis
Jan 7, 2009 10:11 AM
