Brake Noise
Old Mar 6, 2007 | 09:43 PM
500's Avatar
500
500 is infamous around these parts500 is infamous around these parts
Question Brake Noise
1400 miles and my 997S is starting to get a low speed brake squeal; anyone here have this and or a solution? First time I've ever had this problem on a 911
Old Mar 6, 2007 | 10:00 PM
jaxbch987's Avatar
jaxbch987 is infamous around these parts
my cayman s started to make a similar brake noise at 4k miles. i took it in and the service guys said it was b/c my rotors have a slight glaze on them and that i need to get on the brakes hard every so often. they still do it but i have not been able to bring it back to dealer.
Old Mar 6, 2007 | 10:34 PM
500's Avatar
500
So the hard occassional braking did nothing to help?
Old Mar 6, 2007 | 10:39 PM
jaxbch987's Avatar
so far the hard braking has not stopped the brake noise at slow speeds. irritating. i have been accused of nursing the brakes for the first few months of ownership. but, it still seems like they should not make the noise.
Old Mar 6, 2007 | 11:05 PM
500's Avatar
500
Had this problem on a few MB's, the only solution was to change out the rotors. Better bring the car back to the dealer asap, as the less miles the more willing they'll be to replace the rotors.
Old Jun 17, 2007 | 09:10 AM
psalm23and24's Avatar
psalm23and24 is infamous around these parts
Help Fellow members,
I have an 07 GT3 with 900miles and the break make this very annoying squeal when backing up (reversing) and sometimes when slowing down from about 60MPH. Very annoying noise/squeal when reversing is NOT good omen in a thoroughbred and outstanding $100K car. Any help/suggestions/solution direction will be appreciated. Thanks.
Old Jun 17, 2007 | 07:32 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Do you have Ceramics?
Old Jun 18, 2007 | 05:31 AM
No pccb
no i don't have ceramics (pccb). I sure hate the noise/clunk/squeal. Terrible and irritating.
Old Jun 18, 2007 | 09:02 AM
Gpjli's Avatar
In the absense of PCCB I would follow the above advice.
Old Jun 18, 2007 | 10:57 AM
500's Avatar
500
The clunk could be a loose strut or sway bar as my 997S recently had a clunk coming from the psngr front when applying the brakes at lower speeds which was due to a loose strut (apparently a common 997 issue). The only way I've found to really cure the brake squeal is with new rotors and pads. If your car is new with less than +/-2000 miles I'd ask your dealer to intervine w/ Porsche NA for some new brakes.
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
