Removal of Centre rear (LED) brake lamp?
Old Mar 17, 2007 | 08:44 AM
cl997's Avatar
cl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to behold
Would anyone know how to remove the high mounted brake lamp (LED strip) on a 997S? Mine seems to have condensation inside the lens.
Old Mar 17, 2007 | 10:01 AM
Root's Avatar
Root is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of light
Get the hair dryer fired up!
Old Mar 17, 2007 | 11:25 AM
JCS's Avatar
JCS
JCS is infamous around these parts
1. Open the engine compartment lid
2. Remove the 3 torx screws holding the rear panel above the engine hatch
( which contains the brake light assembly )
Have fun.
Old Apr 7, 2009 | 02:47 PM
anthony's Avatar
anthony is just really niceanthony is just really niceanthony is just really niceanthony is just really niceanthony is just really nice
Have fun.
Anyone know if there is there a step 3? I removed the three T30 screws, but I still can't get the panel off -- it seems stuck. Was it supposed to just lift right off after taking the screws out or is there a trick?
Old Apr 7, 2009 | 04:30 PM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
Have you checked Renntech.org? Loren may have an answer for you.
Old Apr 8, 2009 | 01:07 PM
anthony's Avatar
Thanks, I posted over there yesterday, but no response as of yet.
bump
Old Apr 8, 2009 | 10:05 PM
GU10TG's Avatar
GU10TG is just really niceGU10TG is just really niceGU10TG is just really niceGU10TG is just really niceGU10TG is just really nice
Following this thread...I'm interested in knowing how too
Old Apr 9, 2009 | 06:18 AM
cl997's Avatar
I removed the three torx screws but still couldn't work out how to remove the rear panel. It seemed fixed in somehow. I ended up having my Porsche dealer replace the 3rd brake lens under warranty..
Old Apr 9, 2009 | 02:15 PM
anthony's Avatar
Originally Posted by justatoy
If I am not mistaken there are 3 bolts that hold the actuator for rear wing to that panel.....they need to come off as well .
But you got it fixed,congrats!
Stacy
Hmm I looked but I don't see any bolts other than the three torx. Pics attached to help show what I mean.
Yeah it definitely is fixed in there. There has to be a trick after removing the 3 bolts, but I don't know what it is. In the pic where I have my fingers under the panel, that shows the maximum it will come up from the body before it won't budge anymore.
Someone please help
Old Apr 10, 2009 | 12:57 PM
anthony's Avatar
bump
Old Apr 11, 2009 | 08:34 PM
anthony's Avatar
bump
Old Apr 11, 2009 | 09:55 PM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
Is it just being held in there with adhesive and exterior dirt? Have you tried pulling (gently of course) with a hook inside the screw holes? I've not tried to extract this part, but have seen this movie before...
bump
Old Apr 11, 2009 | 11:16 PM
anthony's Avatar
You may be correct, it might be adhesive similar to what holds the outer door sill pieces on (the ones that have the aluminum logo in them with your model designation). If it is that, it's unfortunate because that stuff is STRONG. Guess I will just try pulling harder on it. So far, gently pulling hasn't cut it at all so it's probably time to up the ante. Thanks -Anthony
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
The Oss
Aug 24, 2015 08:19 PM
