Brake / Rotor Advice
Old Sep 8, 2009 | 04:54 PM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
Originally Posted by NorthVan997C2S
Buy OEM, I purchased a few sets of Fronts for $300US (for the pair), and they will work with your car. There is no guarantee that these will work.
I sort of think the same. But, who knows, it does not hurt to ask a question, right?
Pads and rotors will probably be due next fall on my car based on how much is left now. Rotors are actually not bad at all, previous owner was not of fast/furious type.
Old Sep 8, 2009 | 05:04 PM
NorthVan's Avatar
Next fall! Wow, I replaced the Front Rotors in June and they are toast again. I wish some one made a slotted rotor for the C2S, the track usage kills the rotors (cracks from the cross drilling).
Old Sep 8, 2009 | 05:46 PM
utkinpol's Avatar
http://www.autoanything.com/brakes/61A3529A0A0.aspx
looks like slotted to me.
Old Sep 8, 2009 | 05:54 PM
NorthVan's Avatar
Yup, but I am always leery of Kangaroo Paw venting!
Let me preface my previous request, with legitimate supplier. If I am chewing through OEM rotors like I am, what will I do to a cheap rotor like this?
Old Sep 8, 2009 | 07:12 PM
utkinpol's Avatar
Heh. DBA is legit enough - but here is legit one:
http://www.tirerack.com/brakes/brake...PMS&perfCode=A
Old Sep 8, 2009 | 07:28 PM
NorthVan's Avatar
Sure it is legit, but you really need to increase you offer on the CAI for me to buy those. I am cheaper to eat through a few set of OEM rotors at that price.
Old Sep 9, 2009 | 03:07 AM
medpilot105's Avatar
medpilot105 is infamous around these parts
Not having coss-drilled rotors before, I'm curious. Are the cracks just around the edges of each individual hole or do they run from hole to hole before they're due for replacement? Or is the rotor thickness the determining value? I've run ALCON's (non-drilled) before on a different car and never had durability issues. How many track days at say, an intermediate skill level, could a driver expect the OEM rotors to last?
</end questions>
Old Sep 9, 2009 | 05:45 AM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
My rotors were worn and my local shop (good folks who work on a number of high-end cars) recommended these (the Zimmerman's). Seem to be excellent. Actually, 5 months after install, I noticed a very small shimmy on braking in a very narrow set of circumstances. Brought the car in and they warranty'd them. No question.
I'd do it again.
Speaking of rotors - is there any opinion about this product?
http://cgi.ebay.com/ebaymotors/Porsc...ht_3325wt_1165
Old Sep 9, 2009 | 07:06 AM
NorthVan's Avatar
</end questions>
If the cracks are connecting the holes, they should have been long changed. My rotors have 1/4" - 3/8" cracks, with very little surface wear. I have done some very heavy braking (using Pagid Yellows) chasing a bunch of GT3's on various tracks in the NW area.
If used for street only, then you will likely worry about thickness of the rotor before changing.
Old Sep 9, 2009 | 10:51 AM
utkinpol's Avatar
What is the minimal allows thickness, BTW? manual I think says that it has to be replaced when it reaches 1/2 of original rotor thickness or so, but does not say what this original thickness was. Or may be I am mistaken.
Old Sep 9, 2009 | 11:03 AM
NorthVan's Avatar
I think that there is usually a 2 mm difference between a new set and a worn set, but I am not certain to the exact change over either.
Old Sep 9, 2009 | 11:16 AM
Alrighty, then. The car will see an average of four DE's a year so I think I'll be paying close attention to the rotors as well as pads. Thanks!
Old Sep 18, 2009 | 09:27 PM
tedean's Avatar
tedean is infamous around these parts
Is there any spec for when to replace the rotors if the cracks are a certain length?
Rguy
Apr 12, 2020 11:11 PM
Rockinc1
Sep 30, 2015 06:44 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
