Applying power in a corner...
Old May 28, 2007 | 02:41 PM
chokeu2's Avatar
chokeu2 is infamous around these parts
For perspective, I'm coming from a motorcycle perspective, track wise, and have absolutely no track experience in a car let alone a P-car.
So my curiosity is this. On a bike, when you're leaned over in a corner, if you drop power, you have a very high risk of "high siding" the bike, which would send you on an all expenses paid flight across the track, or into the nearest wall face first. Or, when you're leaned in a corner, you can apply power and let the rear hang out a bit to cut the turn even sharper as long as you are smooth.
Can this analogy be similarly tied to a 911 in a corner? I ask because I keep hearing people talking about losing the car in a corner, and I'm trying to create a frame of reference in my mind, in hopes of having a better understanding of the cars characteristics.
Old May 28, 2007 | 02:43 PM
narbo's Avatar
narbo is infamous around these parts
Same principles, however 2wd and 4wd make a difference.
Smooth in Smooth out.
Old May 28, 2007 | 02:55 PM
chokeu2's Avatar
Makes perfect sense.
I've yet to get behind the whell of a 4 yet. So I've no frame of reference. Curious though.
Old May 28, 2007 | 03:01 PM
narbo's Avatar
I upgraded from a SC M3 w/ no traction control. When I took the C4 to the canyons, i noticed with slight acceleration in the corner it made the front dive towards the apex. I have 315's in the back so i have yet to get the rear loose.
But the laws of physics remain the same. we just tweek them a bit.
Old May 28, 2007 | 05:49 PM
doc2s's Avatar
doc2s is infamous around these parts
lean angle for a bike is steering angle in a car. as you apply the power in a car you need to unwind the steering wheel. same as in a bike ou can't be full throttle at full lean. in contrast the bike stand up as you gradually apply power but with a car you need to unwind the wheel yourself.
what you described as sliding the rear to tighten your line is usually done by throttle steering.
Old May 28, 2007 | 08:11 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Get a copy of "Going Faster! Mastering the art of race driving" ,Carl Lopez, Bentley Publishing 2001. A bible of sorts put out by Skip Barber Racing School. A Must read.
Old May 28, 2007 | 08:13 PM
IslandMD615's Avatar
IslandMD615 is infamous around these parts
I believe the beauty of the 911 can be understood by the concept of inertia, where a body resists changes in its state of motion or when something is in motion, wants to keep moving, and when its stopped, it wants to stay put. Now when a 911 is powering through a corner the engine in the rear wants to stay in motion and actually pushes the car out of a turn, explaining the high cornering speeds of this car. but when the 911 is powering through a corner and the power is cut by braking, the engine in the rear still wants to keep going(inertia) and this causes the tail to swing out, which explains the spin outs that can happen. i always wanted to explain this to somebody.
Old May 28, 2007 | 08:25 PM
in other words, DONT LIFT!
Old May 28, 2007 | 08:31 PM
Gramicci101's Avatar
Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !
Here's some good info. It's subaru-based, but driving tips are driving tips.
http://www.spdusa.com/newpage41.htm
Old May 28, 2007 | 09:03 PM
chokeu2's Avatar
I'm happy to say, "I get it!"
One of the worst things you can do on a bike, leaned over is to make a change, and let off the throttle. Sounds the same here. Good explanation Doc and Island!
Old May 28, 2007 | 09:50 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Attend the Porsche Sports Driving Experience at Baraber Motorsports Park in Birmingham or start doing some AutoX and DE's in your area with your car. That is the best way to learn to handle a car.
Old May 28, 2007 | 10:31 PM
Bimota's Avatar
Bimota is infamous around these parts
I think you bought the perfect car coming from a motorcycle background.
Old May 29, 2007 | 07:51 AM
chokeu2's Avatar
Bimota: Coming from a guy who's done the same perhaps?
mdrums: Great guidance! Thats an easy drive from here in Atlanta.
Old May 29, 2007 | 08:42 AM
mdrums's Avatar
Be smooth in your driving, squeeze on the throttle and do not man hamdle the steering.
The Porsche Driving School in Birmingham was worth every penny!
Old May 29, 2007 | 09:17 AM
TT Tommy's Avatar
TT Tommy is infamous around these parts
IslandMD explained it properly. The beauty of a 911 IS that it is tail heavy. When braking, the weight transfer becomes close to 50\50, when accelerating the weight goes to the rear and applies massive traction to the already heavy tail. unfortunately when the car is decellerating at the wrong place in a turn (lifting to much or braking) it upsets the balance. The rear of the car lightens and reduces the hold at the back then the laws of inertia take over with the back wanting to be at the front
As others have stated, take a good DE course pertaining to a 911. Skippy School or Porsche Experience if possible.
Enjoy your car!
tw
