Help: Oil Question
Old Jun 14, 2007 | 09:18 AM
david7979's Avatar
david7979 is infamous around these parts
Help: Oil Question
Members,
I just check the oil on my 997 and its down to 2 bar. How much Oil should I add? 1 QT? 2QT? or more??
Thank you
Old Jun 14, 2007 | 09:49 AM
wdonovan's Avatar
wdonovan is infamous around these parts
If you mean 2 bars showing on the oil level check, then add 1 qt. It should barely take this without an overfill condition. If you mean 2 bar of pressure on the pressure gauge, I'll let someone else do this one.
Old Jun 14, 2007 | 10:39 AM
larrytrk's Avatar
larrytrk is infamous around these parts
I always keep at 3 bars,1 bar low, no worry about overfill! Worst is up to 4 bars if I add more than I want!!
Old Jun 14, 2007 | 11:17 AM
Eric523's Avatar
Eric523 is infamous around these parts
The digital guage only reads about the last quart of oil. So be careful not to overfill.
Old Jun 14, 2007 | 11:21 AM
david7979's Avatar
i saw it on the forum that its good to have either 3 or 4 bars. is that true? Its down to 2 bars.
Old Jun 14, 2007 | 11:22 AM
david7979's Avatar
it was showing 4 bars not too long ago and it is showing 2 bars now. how much should I add not to overfill? 1 QT? or less?
Old Jun 14, 2007 | 12:07 PM
Eric523's Avatar
I would say half a quart at the most. It's a little more time consuming to fill up in small incraments, but overfilling is a PIA to take care of.
Old Jun 14, 2007 | 12:08 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
A "bar" is .4 qt Do not add more than 1/2 qt at a time Make sure car is on level ground when you check oil Don't get crazy about it
Old Jun 14, 2007 | 12:43 PM
david7979's Avatar
thanks guys...
Old Jun 14, 2007 | 12:44 PM
david7979's Avatar
why do they burn so fast? I was at 4 bars not too long ago..
Old Jun 14, 2007 | 03:37 PM
Gpjli's Avatar
The manual explains the build up of condensation in the oil on short trips and the burn off on longer trips when oil runs hotter. Oil level seems to drop rapidly. Read the section on oil. In fact, RTFM
Old Jun 14, 2007 | 04:47 PM
jhbrennan's Avatar
Originally Posted by david7979
Members,
Thank you
I have to ask - where's your owner's manual (either paper or e-version)??
Old Jun 14, 2007 | 07:54 PM
porschenut911's Avatar
porschenut911 is infamous around these parts
Dealer told me 1 bar = .25 qt. Add little by little and check every time you do .25qt.
Old Jun 14, 2007 | 11:26 PM
david7979's Avatar
thank you guys..
Old Jun 15, 2007 | 06:51 AM
jhbrennan's Avatar
Each bar = 0.4 liters (about 0.42 quarts) - this is from the owner's manual.
