check oil light comes on after refueling?
Old Aug 18, 2007 | 06:59 AM
bigg's Avatar
bigg is infamous around these parts
Question check oil light comes on after refueling?
anyone know whats up with the check oil light that comes on from time to time after refueling? is it a reminder or what? can't get a straight answer. comes on even when oil is on max
Old Aug 18, 2007 | 08:01 AM
jreeves197's Avatar
jreeves197 is infamous around these partsjreeves197 is infamous around these parts
I noticed the same thing with mine. It dosen't happen everytime. I think it does it once in awhile if you haven't checked it in a long time, just to make sure you're doing it ever so often. I may be wrong, its just what I've noticed.
Old Aug 19, 2007 | 03:22 PM
bigg's Avatar
i've asked several porsche service centers they look at me like i'm crazy but i think you are correct
Old Aug 19, 2007 | 03:26 PM
globalm3's Avatar
globalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond repute
mine does it to know that you say it.... hummm weird
Old Aug 20, 2007 | 07:42 AM
wdonovan's Avatar
wdonovan is infamous around these parts
"Mine does it too, now that you say it." Did I get it right? This one took me a while.
Old Aug 20, 2007 | 08:21 AM
paragongja's Avatar
paragongja is infamous around these parts
Happens to me too. But never once did I actualy ned oil.
Old Aug 20, 2007 | 10:46 AM
jhbrennan's Avatar
Maybe it has something to do with the oil level measurment function during refueling. The owner's manual says "The oil level is automatcially measured during refueling" and then it goes on to explain the preconditions, etc. Could be that you're interrupting the "automatic" process although I never had this happen. See what the manual says on page 119 of the 2006 manual.
Old Aug 20, 2007 | 10:58 AM
globalm3's Avatar
I think I just found the reason.... I only noticed it once when I was in a hurry and put 5 dollars in..... Maybe if yoyu don't pump a full tank it interupts the oil checking process? Just a theory
Old Aug 20, 2007 | 01:55 PM
C2S4ME's Avatar
C2S4ME is infamous around these parts
Read page 119 of your owners manual. If the engine is at operating temperature and then turned off for between 5 and 15 minutes, when the ignition is turned back on engine oil level will automatically be displayed.
Old Aug 21, 2007 | 07:45 PM
mkaraoglan's Avatar
mkaraoglan has a spectacular aura aboutmkaraoglan has a spectacular aura aboutmkaraoglan has a spectacular aura about
yup. same here, which is why i realized i was low a quart or so this past weekend ( i have another thread on oil consumption)
Old Aug 22, 2007 | 12:44 PM
bigg's Avatar
thanks that
Old Aug 22, 2007 | 01:20 PM
dertub's Avatar
dertub is infamous around these parts
Make sure you twist the cap closed 3 times. I even bought a new cap with a larger gasket. I disconnected the battery to clear the codes. It hasn't happened since.
Old Aug 22, 2007 | 02:13 PM
globalm3's Avatar
just went by the dealer my oil was low to.... good job
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
GSR Autosport
Aug 26, 2015 05:20 PM
