Picked up a new intercooler heat exchanger
Old Oct 8, 2010 | 07:22 AM
Blitzkrieg's Avatar
Blitzkrieg is infamous around these parts
So the unit came in and it is installed. The way I installed it made for a VERY tight fit behind the grill. I wanted it positioned so that I did not have to relocate the power steering cooler and keep the original exchanger. I plumbed the new exchanger in series with the old one. There is a flange that hangs down from the metal bumper. I drilled holes and hung the exchanger from it with M8 bolts. I positioned the core so that the petcok is positioned upwards and used as an air bleed. I removed and cut the foam bumper to clear the petcok area. All in all it came out nice. I did not get the chance to datalog the AITs as of yet but I can tell you that the lid feels much cooler for longer after idle time. I will log the AITs tonight at Atco when I run the car. Read more at http://www.cadillacforums.com/forums...html?kcplink=1
Old Oct 15, 2010 | 08:15 PM
Doc GTO's Avatar
Doc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond repute
Nice setup. I did a dual pass on my GTO over the single that Maggie supplied with the TVS2300. I also upgraded the water tank with a Moroso one that holds more fluid and can be packed with ice at the track.
danyoP4S
Sep 30, 2021 05:06 AM
Michael_s
Sep 11, 2015 08:03 PM
HolmaN
Aug 19, 2015 07:32 PM
