Chrysler 300c w/ JDM & DTM roots
Old Mar 27, 2014 | 10:57 AM
  #91
Rickdogg's Avatar
Rickdogg is infamous around these parts
I apologize for the delay guys. We were busy tinkering away for Spring Fest 9 and had a lot of varying issues arise.
Here is a photo showing a stock 300c headlamp vs. 1 Single Q45 Retrofit vs. A Dual q45 retrofit setup:
The Quad q45 setup from Essential Lites. All metal brackets and most importantly looks stock from the back with rubber seals and all.
Parking lights on. These are not HiD's on at this point. These are reverse mounted XBLED's (aka Halos) from The Retrofit Source. Yes, we wanted to do something different and didn't want to do the "typical halos."
HID's vs. signals on! A hole was drilled out to fit an amber LED blinker bulb and the "rings" are actually strategically placed LED strips from The Retrofit Source. You have to look really, really close to see them.
ID:	351738   Click image for larger version
ID:	351739   Click image for larger version
ID:	351740   Click image for larger version
Old Mar 27, 2014 | 11:39 AM
  #92
Rickdogg's Avatar
All engine panels etc were removed to make it easy to work with the supercharger install. Here's the initial bracket etc mounted up.
Here it is with FMIC and piping run. The piping on the driver said was a head scratcher, but we soon figured out that it needed to be modified lol
After battling with the Supercharger install with hiccup after hiccup it is on and ready to go:
We then headed over to the @OCMufflerman to get the exhaust installed. Yeah, the welds could have been cleaner but the last minute decision to make a splash at Spring Fest really put us in a bind.
The race mufflers sit just before the rear flanges:
ID:	351749   Click image for larger version
ID:	351750   Click image for larger version
ID:	351751   Click image for larger version
ID:	351752   Click image for larger version
ID:	351754   Click image for larger version
Old Mar 27, 2014 | 11:56 AM
  #93
Rickdogg's Avatar
The final push is Real!!! The car was finally buttoned up at 3am the day of the show. With all of the hard work put in and all of the support received from Diablosport, AMP, BFNY, Inertia, etc. It was truly rewarding to record this video of the car running.
Side view then moving to the front:
ID:	351758   Click image for larger version
Old Mar 27, 2014 | 12:07 PM
  #94
Rickdogg's Avatar
Prepping for the show all week really put me out of commission. I'm usually more social, but I literally was just drained. I apologize for those that I missed at the show, but hopefully I can catch some of you guys at future events.
Luckily, there were a few awesome folks that were able to snap pics:
ID:	351766   Click image for larger version
ID:	351767   Click image for larger version
ID:	351768   Click image for larger version
ID:	351769   Click image for larger version
ID:	351771   Click image for larger version
ID:	351772   Click image for larger version
Old Mar 27, 2014 | 12:11 PM
  #95
Rickdogg's Avatar
Vossen Wheels was kind enough to place the 300 at the opening scene of their video coverage of the Spring Festival 9 event:
http://youtu.be/vkRR2UT3SCk
R1 Concepts was also nice enough to place the 300 at a prime location of their video coverage of Spring Fest 9 when the music drops at the 46 Second mark. Awesome rotating shot!
http://youtu.be/KariCPUT1fo
Old Jan 10, 2015 | 01:05 AM
  #96
Rickdogg's Avatar
Originally Posted by noremac
Update your thread!!
Cameron, not much to report after the supercharger was put on. The car is finally ready to see the dyno soon though just to see where it's at.
Finally installed the gauges and overhead gauge pod
Had a little fun in front of Chino state prison
Some updated sound clips:
We will Be upgrading the q45 projector hardware to 55w for 2015
Some new shots:
Old Jan 23, 2015 | 03:15 AM
  #97
Rickdogg's Avatar
Found one of the Power Steering single pass units for a steal, so I test fitted it to see if I wanted to mount it on the bumper support or higher up. I think higher up is the winner to make room for the oil and tranny coolers in the future.
The factory horns have to be relocated or the mounting brackets will have to be modified for a tight fit. I'll just opt to relocate them to make room for a larger radiator down the road.
The chosen mounting location:
Old Feb 19, 2015 | 10:58 AM
  #98
Rickdogg's Avatar
So it looks like I will be adding the Razors edge Motorsports front bumper support to shave a few pounds that I probably put back in Dynamat lol. Going to have it powdercoater by Baid Polish.
Old Feb 20, 2015 | 09:28 PM
  #99
Rickdogg's Avatar
After looking at the boring factory interior for a while, I decided to try to learn something new and skin the interior pieces for a different look. I opted for black and silver (actually texalium) in place of where the factory silver bezels are to somewhat retain a factory look, but with some bling!
Since it was my first time trying i pulled some random test pieces to experiment with.
I swear that rear pillar on the back window is a pita to work with. I don't look forward to reinstalling it.
Some initial prep:
Old Feb 20, 2015 | 09:35 PM
  #100
Rickdogg's Avatar
Decided to yank the backings on the 2010 challenger seats as well
Diboblo and I are thinking of swapping the led's in the seat backings out to something custom
The "horseshoes" or u-shaped pieces on the backing were all siliconed in so had to remove them to allow the cf process
Old Feb 20, 2015 | 09:38 PM
  #101
Rickdogg's Avatar
Some chemicals and my miscellaneous starter kit with Betty Crocker of course
Never had use for the bottom floor bathroom, but made my "a beautiful mind" setup for this experiment.
The fabric has arrived!
Old Feb 20, 2015 | 09:40 PM
  #102
Rickdogg's Avatar
The first 4 guinea pigs are the 2 horsehoes, rear window switch bezel, & one rear door pull
First time pressing the fabric on to the pieces
Old Feb 20, 2015 | 09:41 PM
  #103
Rickdogg's Avatar
The initial layer of epoxy
Old Feb 20, 2015 | 09:42 PM
  #104
Rickdogg's Avatar
The first trim after the first coat dried
After some more trimming and second coat of epoxy down
Old Feb 20, 2015 | 09:44 PM
  #105
Rickdogg's Avatar
Plenty of steps left, but I just wanted a quick test fit so I could trim the main backing as much as possible while the epoxy is thin before I layed down more layers.
