When people see the exterior of the car, they think immediately the interior matches the upgrades made to the exterior. I still have the oem base sound system.
My goal in this Build is to have great SQ with good level of output as well. keep a good portion of useable space in the trunk. The build will display materials and style I would use in builds I do. Problem Ive had for a while has been when I'm ready to get this build started, what equipment would I want to use.
Since I carry some of the best SQ product brands, how do I choose? since they all have great craftsmanship, quality parts, performance and support. First I looked at what would work well in my type of car, Speaker locations and size. After that the performance for the budget I wanted to invest in. I feel most of the budget should go to the front stage, DSP, Amp and then sub in that order. The air ride system will be cleaned up and organized in a different fashion in the trunk area. It will be a long build since im working on other builds at the moment. My goal is to have this complete by end of winter. Here are some of the components I will be using.
Source - Sony MEX-GS610BT and Tablet
Front stage- Ground Zero Plutonium limited edition 3 way
subs - Ground Zero Hydrogen 30x 12" subs or illusion Audio c12xl
Amps - Ground Zero Uranium GZUA 250.2SQ and GZUA 150.4SQ
DSP - Mosconi 6to8 v8 with mini controller
Sound Deadening - Ground zero and STP deadening and ccf
Current Mods
- 22x9.5 4.5" lip front 22x11 6" lip rear
- Nexen N3000 tires 265-35zr22 front 295/25zr22 rear
- Universal Air Suspension air ride setup
- Flowmaster American Thunder Cat-back system.
