'68 GT500 How HOT is Too HOT? 220degrees?
Old Jun 15, 2007 | 10:08 PM
MrTheKid's Avatar
MrTheKid is infamous around these parts
Never had a car run sooo hot. 200 is o.k. 215 is on the warmer side right?
i have a GT500 w/ a 427, sometimes if i am in the city the water temp will run up as high as 230 degrees, at what point do i start to worry?
i can go on the freeway at 225 degrees and at an even 80mph the water tempreature will quickly decrease to 185-190.
Oil Pressure is Normal 50 or so
what suggestions do any of you have for me to begin running proper diagnostics on this if it's an issue?
THANKS
Old Jun 15, 2007 | 10:16 PM
Vicious's Avatar
Vicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond reputeVicious has a reputation beyond repute
AL or cast iron motor?
230 is getting up there. Your radiator is too small from what I can see, get something much wider, triple pass, and run 2 very powerful fans on it. It shouldn't get much over the thermostat temp even in traffic.
50psi, I take it thats oil pressure?
Old Jun 15, 2007 | 10:24 PM
NaplesBound's Avatar
NaplesBound is just really niceNaplesBound is just really niceNaplesBound is just really niceNaplesBound is just really nice
It takes two cop cars to pull you over? lol
Chris
Old Jun 15, 2007 | 10:28 PM
MrTheKid's Avatar
yes aluminum
Old Jun 15, 2007 | 10:29 PM
MrTheKid's Avatar
Chris
GT3 Chuck's Avatar
Administrator
that radiator is a nice looking piece but is way too small for that motor in traffic...can't really see the fan and shroud but they are probably as big as they can be for that radiator...if not try that...a 150 degree t-stat might help if you are running a 180...beautiful car...
Old Jun 15, 2007 | 10:57 PM
nvrsetl's Avatar
nvrsetl is infamous around these parts
This is the first time I've seen your car. And I have to say that is one GORGEOUS shelby!!! A true collector piece.
Cheers,
Mark
Old Jun 15, 2007 | 11:15 PM
AaronK's Avatar
AaronK is a jewel in the roughAaronK is a jewel in the roughAaronK is a jewel in the roughAaronK is a jewel in the rough
I would have to agree that your radiator is probably too small. I am running a set up from Ron Davis and it is much bigger radiator with dual fans. You may be able to switch to just a dual fan setup. Check with Unique and see what they say.
http://www.rondavisradiators.com/radgallery.htm
Old Jun 15, 2007 | 11:22 PM
MrTheKid's Avatar
THANKS.. man all you guys have been very very helpfull.. it has a single fan right now, i'm sure i'll go dual then.
I put a 400 chevy motor in my 1950 Merc and we put some HUGE fans in that thing, it NEVER gets past 150 (knock on wood)
Old Jun 16, 2007 | 01:43 AM
Secure's Avatar
Secure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud of
Should never get past thermostat temp if cooling is right.
Old Jun 16, 2007 | 07:10 AM
Renoir's Avatar
Renoir is infamous around these parts
That's way too hot...call UP.
Old Jun 16, 2007 | 08:26 AM
black430's Avatar
black430 is infamous around these parts
why not ask the people that built the car.....
Old Jun 17, 2007 | 11:44 PM
D-VO's Avatar
D-VO is infamous around these partsD-VO is infamous around these parts
get a bigger radiator, and possibly a lower temp thermostat. if you're still having trouble, try heat wrapping the exhaust headers.
Old Jun 18, 2007 | 10:16 AM
MrTheKid's Avatar
the people who built the car, want to always dance around how perfect they think the car is... with excuses as to why the car "might" be running hot.. altitude, humidity, etc. no real suggestions on how to "fix"
i am a problem solver, and you guys help'd.. THANKS.
i want the car to run cherry so i can drive it 3 days a week in any condtion !
tomoroow i will discuss the idea of a bigger radiator, 2 twin fans, lower therm. and we'll see what those guys at UP think.
THANKS AGAIN !
Old Jun 18, 2007 | 11:21 AM
evsmotors's Avatar
evsmotors has a spectacular aura aboutevsmotors has a spectacular aura about
A couple of suggestions. Everyone is right about the radiator being too small for a big block. I would also check to see how the radiator electric fan is setup. I suggest having the power wire from the fan run directly on the battery so it will run at its max power. Check to see what the temperature setting is on the thermostat. If your not running a/c put a pusher fan on the front of the radiator. I'm sure UP set the fan up correctly but it never hurts to check and make sure the fan is really pulling air instread of pushing. I've seen this happen before. Its not necessary to run dual fans, thats not always the best setup. We've run 1,000HP cars with single clutch fans with no problems.
