Can't locate ECU in my 06 V8V... help please...
Old Jan 18, 2010 | 03:48 PM
zambono's Avatar
zambono has a spectacular aura aboutzambono has a spectacular aura aboutzambono has a spectacular aura about
So I am trying to pull out the ECU to send to RSC and I have not been able to locate it. Per RSC I removed the passenger side front wheel then the wheel liner screws. I wasn't able to remove the liner much, it is hard plastic and didn't want to snap anything by pulling too hard.
I couldn't find it though. I looked in the manual and I noticed that the fuse box is opposite in my vehicle than what the manual states. My fusebox is in the passenger side, the manual states driver side. Can someone confirm with me the location of their fusebox and more important the ECU.
also looking into the wheel arch is the ECU towards the front from the shock or towards the passenger cabin. thanks much.
Old Jan 18, 2010 | 03:50 PM
cshsia's Avatar
cshsia is infamous around these parts
good timing, check you PM and see if that document helps.
Old Jan 18, 2010 | 04:38 PM
zambono's Avatar
thanks, but not sure if thats a RHD vehicle doc. It definitely helps some though. Can I get a confirmation from someone on here who has removed his/her ECU, US spec.
Old Jan 18, 2010 | 04:45 PM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
US spec, you were close, remove right front wheel and wheel liner, yes it is there, not in the cabin of the car. Upper left inside wheel well. I have seen it ... and had it removed.
Old Jan 18, 2010 | 04:46 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
Sorry I can't help but I am contemplating doing the RSC ECU upgrade in the spring. Can you please let us know your impressions and can I get a copy of the document too? Good luck.
Thanks,
Adam
Old Jan 18, 2010 | 04:47 PM
zambono's Avatar
man I didn't see it, did you remove the liner completely? I wasn't able too, per service manual there are 23 screws to the liner, lol, I had 9 removed.
Old Jan 19, 2010 | 12:21 AM
zambono's Avatar
I didn't pull too hard from the liner either, I didn't want to snap anything
Old Jan 19, 2010 | 12:01 PM
zambono's Avatar
anybody with info as to which and how many liner screws should I remove to get at the ECU? I did the most visible 9 and it didn't budge much.
Old Jan 20, 2010 | 02:42 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
ECU is circled. You need to pull on the inner fender after unscrewing.
Old Jan 20, 2010 | 03:04 PM
alevine's Avatar
Cool. That will be very helpful for me when I do this mod in the spring.
Thanks!
Adam
Old Jan 20, 2010 | 06:24 PM
Fantasma's Avatar
Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !
2006 models didn't come with ECU's
Old Jan 21, 2010 | 07:34 AM
cshsia's Avatar
you're talking about the chip that controls the engine or the fancy AM marketing term for the new glass key?
Old Jan 21, 2010 | 07:58 AM
rick-dms-'s Avatar
rick-dms- is infamous around these parts
the engine ecu is NOT the one circled, this is a picture of the engine ecu
Old Jan 21, 2010 | 04:05 PM
alevine's Avatar
Cool. Thanks. I see the ECU in the original picture to the upper left.
Glad you pointed this out!
Adam
Old Jan 21, 2010 | 04:10 PM
zambono's Avatar
thanks much guys, lets see if the weather behaves this weekend and I can get at it. at least now I know where to pull from.
