Got my 07 V8V, help with a clanking noise
Old Mar 20, 2011 | 09:06 PM
111R's Avatar
111R is infamous around these parts
It was finally delivered a couple nights ago (PlyCar transport, in a covered carrier, covered in plastic. I am not new to the quirks of hand built british cars and was expecting a few gremlins in the works. So far I have two:
-The digital speedo has blinked out only to reset itself after the car was restarted a few times. The screen was totally blank, but the LCD was working, i.e. the AM logo did show on startup and when clicked it would flash the 'no messages' from the blue tooth.
-The clancking noise
This is more troubling to me. It's located in the left front wheel general area, happend 3 times in the 200 miles I've driven so far and only when I'm turning more than 60-90 degrees and once when I went over a hump in the road contour at about 40 mph. I've eyeballed the region and nothing is loose. The sound quality is that of clanking hollow pipe. Tonight was bad enough that I pulled off thinking it was dragging on something.
Any ideas on these two?
The car is mechanically fine and the suspension, brakes seem to be working fine (without a frame of reference).
Old Mar 21, 2011 | 08:53 AM
jrkr's Avatar
jrkr is infamous around these parts
111R. One of the options for the right screen on the instrument pack is a blank screen, if memory serves me correctly, the "Power, Beauty, Soul" will show then it will go to it's blank screen setting. You can cycle through the screen options by pressing the button on the end of the indicator stalk. (Apologies if you already knew this).
A somewhat common cause of clunking noises can be the strut bracing. Make sure the 12 torx-50 bolts are tight, check them when the car is on level ground. I have yet to see a bad one myself, but I have heard of issues with the front top A-arm bushings causing noises. I hope you find some of this info useful. Cheers, John.
Old Mar 21, 2011 | 09:43 AM
droffsite's Avatar
droffsite is infamous around these parts
I've had (I believe) the same clanking issue. Some times it sounds as described, other times it sounds like running over a piece of sheet metal that fell off. I've also looked and haven't seen anything that appears loose.
Old Mar 21, 2011 | 09:58 AM
111R's Avatar
John
Thanks for the reply. I am ignorant of the blank screen setting. But to clarify, it was only the right hand one for the digital speedo and only the speedo setting. Turning on and off did not make a difference till I let the car sit. RFM I guess! or as we say in the Lotus world TADTS (they all do that sir)
I am also ignorant of the strut bracing you mention. But this gives me a direction to go searching and educating myself. It was quite frankly an ominous noise as if I had a hose hanging rattling around in there!
Old Mar 22, 2011 | 12:08 PM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
Also a recall (NHTSA Campaign ID number 10V449000) V8/DB9/DBS MY 2007/2008 (by SN only) for "Susupension: Front Control Arm: Lower Control". Maybe your car ? Dealer will look up and fix for free.
Old Mar 22, 2011 | 01:15 PM
111R's Avatar
Well the catch there is that the car came from a dealer and all recalls were supposed to be done. Alas the one nearest to me is 600 miles away.
Old Mar 22, 2011 | 04:46 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
Your dealer can look up in the computer and tell you if all recall campaigns have been performed.
Adam
Old Mar 24, 2011 | 11:51 AM
eatnow's Avatar
eatnow is infamous around these parts
Rooooooad Triiiiiiiiiiiip!!!
rob4wellness
Oct 2, 2015 07:32 AM
V565MAN
Oct 2, 2015 05:48 AM
Ronny-
Sep 30, 2015 07:30 PM
