Need to touch up interior door handle
Old May 5, 2011 | 09:33 AM
zambono's Avatar
zambono has a spectacular aura aboutzambono has a spectacular aura aboutzambono has a spectacular aura about
hope surgery went well, any info and pics on how you wrapped the door sills and instruments
Old May 5, 2011 | 01:32 PM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
duh ... Toyota grey ... geez have a Met. Grey 4Runner in the driveway and touch up paint in the garage right next to my AM touch up paint kit! So just tried it ... yep Toyota grey worked nicely. It is Toyota - "1E9" P/N 00258001E921 ...
Old May 5, 2011 | 08:38 PM
brumma's Avatar
brumma has a spectacular aura aboutbrumma has a spectacular aura about
The one that was suggested to me is "IE3" actually. It's been too humid around here lately to test it though. I should get the chance this weekend.
Old May 6, 2011 | 06:36 AM
Update - Not sure about the difference between IE3 and 1E9 - maybe just an update as body styles change?
The one I used yesterday (5/5/11) 1E9 is now dry and is a very good match for a small "chipped out" area I had on passenger side. Also 1E9 does have a touch of "metallic" in it as do the AM door handles.
Old May 6, 2011 | 01:03 PM
zambono's Avatar
carbon film, did you also cover the actual lever in the door handle? pics and info would be great. thanks
Old Jun 19, 2012 | 09:05 AM
Paul Holbrook's Avatar
Paul Holbrook is infamous around these parts
Think I have the answer...
Guys,
Not sure if you have a solution to this chip problem for the interior door handles but I found a really close match.
I went to Halfords in the UK and found Peugeot Iron Grey. It's damn close and great for small chips. I can't see the difference without really really looking.
Hope this helps,
P
Old Jan 1, 2014 | 09:13 PM
V12Vin's Avatar
V12Vin
Just a quick update on touchup paints.
Testors Graphite Grey enamel (#2712) works. Apply using a small paint brush available from craft stores.
Old Jan 2, 2014 | 08:25 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Hide the chip[
An instant fix, use a black felt marker pen...done, while you contemplate a permanent repair.
A year or more ago a Brit on Pistonheads, was going to strip his DB9 parts. Same as Vantage, they are aluminum. Never read of his resolution.
If you strip your parts consider this:
For an attractive, forgiving finish, buff with a fine steelwool pad or equivalent. Clear topcoat would be optional.
Last edited by flinder; Jan 2, 2014 at 11:07 AM. Reason: Complete an incomplete thought
Old Jan 2, 2014 | 08:46 AM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Might want to try - European Motor Works in Santa Anna, CA. I understand they mix for some authorized AM repair facilities. I gave then my VIN and color needed. Got some touch up for under $20 and was very pleased. 714 957 1290. Can't recall who I spoke with a year ago but he was super helpful.
nlakind
Nov 6, 2015 10:15 AM
SRC4S
Sep 1, 2015 09:22 AM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 26, 2015 12:13 PM
TrackOne
Aug 20, 2015 12:56 PM
