oil change '06 DB9
Old Apr 29, 2011 | 09:07 PM
Shooter Martin's Avatar
Shooter Martin is infamous around these parts
oil change '06 DB9
Hello, over the winter months I installed a Bend Pac 4 post lift in my garage and want to start doing my own maintenance on my '06 DB9, I first want to change the oil, does anyone have any insight on this or can recommend a detailed walk thru, I know that I would have to remove the lower pan and remove something under the hood as well but a detailed step by step would be great, thank you
Tom
Old Apr 29, 2011 | 10:21 PM
XJRS Owner's Avatar
Tom
Changing the oil itself is easy...just remove the bottom sheet metal and the rest is obvious. The filter must be removed from the top side and there is NO room to get a tool on it plus your arm (that's after removing the driver's side throttle body). I spent an hour trying to access the filter with every type of filter removal tool and I gave up.
If you figure out how to get the oil filter off you are a better man than me. It's impossible for all practical purposes. I suspect that half the time dealers tell you they've changed your filter but really don't.
That's my take on it.
Old Aug 25, 2011 | 08:55 PM
TomDB9's Avatar
TomDB9 is infamous around these parts
Can't help you on the oil change but I have an '06 DB9 in Meteorite Silver over Obsedian Black. Great car & color combo. Enjoy your ride. Cheers, Tom
alwaysbored786
Apr 19, 2016 05:51 AM
4ocious
Sep 1, 2015 06:44 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
