So I bought a V12 Vantage . . .
Old May 15, 2011 | 12:48 PM
  #46
g3t_t0rk's Avatar
g3t_t0rk is infamous around these parts
Congrats! Love Aston Martins!
Old May 15, 2011 | 02:11 PM
  #47
spainconection's Avatar
spainconection is infamous around these parts
CONGRATULATIONS!
just what I hope and desire is that you never have oil leak by the front cover, you want to die, enjoy ....
Old May 16, 2011 | 09:11 AM
  #48
cam99's Avatar
cam99 is infamous around these partscam99 is infamous around these parts
SWEET!
I'm jealous
Old May 16, 2011 | 04:57 PM
  #49
KidRacer's Avatar
KidRacer is infamous around these parts
Originally Posted by Racer_X
Quick update: Pulled fuse 15 yesterday. What a huge difference it makes. One thing I have been thinking the car is lacking is a more aggressive exhaust note. When just cruising, it's so quiet you can hear the transmission whine (which is not a bad sound). Pulling the fuse fixed this completely. The car now has a proper growl across all rpms. I had been considering an aftermarket exhaust, but now I don't think it's necessary.
interesting! what made you think of pulling a fuse to make the exhaust sound better? does fuse 15 effect anything else?
Old May 16, 2011 | 06:06 PM
  #50
Tahoe M3's Avatar
Tahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really nice
It controls the exhaust flap, so pulling the fuse keeps the flap open. It's common across all AMs...on the Vantage it's fuse 22.
Old May 16, 2011 | 06:14 PM
  #51
KidRacer's Avatar
can keeping it open all the time like that cause any damage?
Old May 16, 2011 | 06:28 PM
  #52
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
It doesn't appear so. Tons of guys have done this on their cars to no ill effect. Also, Mike (AM Dragon Maker) has recommended removing the fuse to get the better sound.
Over concerns the fuse might also be linked to another car system, some have chosen to instead tie off the pneumatic lines that are used to keep the flap open. This is another option, although it requires putting the car on a rack and I like the ability to easily change the sound by just removing/inserting the fuse. For example, I'd probably replace the fuse before a long trip to reduce highway drone.
Old May 17, 2011 | 03:34 PM
  #53
KidRacer's Avatar
picking up my car tomorrow. so excited i feel like a little kid again.
have you figured out what the sweet spot is in terms of RPM for changing gears?
Old May 17, 2011 | 03:45 PM
  #54
jaymoney's Avatar
jaymoney is a splendid one to beholdjaymoney is a splendid one to beholdjaymoney is a splendid one to beholdjaymoney is a splendid one to beholdjaymoney is a splendid one to beholdjaymoney is a splendid one to behold
You're governed to 6K until you reach 1200 miles. So I shift at 5500-6000 and that is pretty awesome. I have gotten bumped down a couple of times when I hit the limiter. You basically feel a loss of throttle to about 4000. Give it some time, I think that you will find that you run out of pavement a lot so you may be shifting at times that aren't optimal. I have found that this car is hungry to go fast, so it really likes to rev and get going. The first time your tooling around and you have to let you foot off of the gas you'll hear a bit of a growl as if the car is disappointed that you are slowing. It really is amazing.
Old May 17, 2011 | 03:53 PM
  #55
Tahoe M3's Avatar
First off, congrats on the new delivery tomorrow!
As for the question, this one always strikes me as odd when I see it, and my answer is always to run it to redline in each gear for maximum acceleration. When the engineers design the car, they ideally set the gears up with the engine so that with each gearchange the car doesn't drop outside of its power sweet spot. And max power is almost always very close to redline. Even if it drops down a bit, the car is still making more at redline (and with a higher gear multiplication) than it will in the next successive gear, so run it to redline in each gear. For the most part short-shifting will only hurt your performance.
Old May 17, 2011 | 06:42 PM
  #56
markesq's Avatar
markesq has a spectacular aura aboutmarkesq has a spectacular aura about
So jealous!!!
Old May 17, 2011 | 06:55 PM
  #57
Racer_X's Avatar
Absolutely. If you are looking for maximum acceleration, you shift at peak power. For the Aston, that's the red line.
Old May 17, 2011 | 06:57 PM
  #58
Racer_X's Avatar
Congrats on the car. Looking forward to see some pics. I may be taking my car to the mountains along with a group of other drivers this weekend and hope to get some pics done there.
Old May 18, 2011 | 06:15 PM
  #59
markesq's Avatar
I test drove one a few months ago. It is definitely going to be my next car. It has what we all love about the Vantage and the power to match. Perfect car.
Old May 18, 2011 | 06:40 PM
  #60
jpohl402's Avatar
jpohl402 is infamous around these partsjpohl402 is infamous around these parts
congrats !
killer car...
