failsafe mode??
Old May 4, 2011 | 10:53 PM
brabham79's Avatar
brabham79 is infamous around these parts
failsafe mode??
has anyone experienced this before?
i went on a long roadtrip from orange county CA, to sonoma, through monterey and san fran this past week. on 3 separate occasions the car slows to a crawl with the red warning exclamation and a message reading engine failsafe mode.
stopped the car turned it off, counted to 5 and turned it back on, no muss no fuss, no warning message nothing. car runs great...
these instances occured shortly after massive differences in driving habits (aka long steady bouts of even freeway driving, then all of a sudden stop and go city, etc) so i kind of chalked it up to the ecu freaking out and not knowing how to regulate the mix of air/fuel, etc.
and again, i would jsut wait a couple seconds and she turned over no problem and ran great until the next massive change in driving habits!
weird and scary
Old May 5, 2011 | 07:40 AM
RPVantage's Avatar
RPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to behold
I use to have the same issue with a 05 Jaguar S Type R I used to own, the problem was in the throttle body. Happened 3 times and I had put it in a flat bed every time.
I didn't know Aston had a similar issue.
Old May 5, 2011 | 11:51 AM
brabham79's Avatar
it doesnt seem to be detrimental other wise it wouldnt start up with no issues instantly...again weird. anyway heres a shot in monterey on the way up
god this thing shoots amazing all the time!
Old May 8, 2011 | 05:26 PM
droffsite's Avatar
droffsite is infamous around these parts
Just had this happen to me, but because of my own stupidity. Just changed my thermostat, then started the car up to see if I had any leaks. It sounded horrible, and the display indicated failsafe mode. Then I remembered that I'd forgotten to reconnect the wiring harness on the left under the throttle body.
I'm guessing you didn't change your thermostat while on your trip, but maybe you have a loose wiring harness connection somewhere.
Old May 8, 2011 | 07:00 PM
AM Dragon Maker's Avatar
AM Dragon Maker is infamous around these parts
weird and scary
Hi fella.
If the ECU is not disconnected from the battery the P codes stored will remain in the OBD freezeframe data. So a fault code scan checker will reveal the reason for the fault. If I was a betting man I would guess that a code which refers to fuel rail pressure measurement, but specifically the robustness of the measurement is at fault. If this is the case then there is no fault and this is an error in the hardware system which the OBD monitor serves to do nothing other than irritate you... but it's possible it could be any number of reasons.. Are you under warranty?
PS: you just reminded me of the time I hired a Harley and cruised from san fran to LA - you are a lucky man Highway 1 and Aston..!
Old May 9, 2011 | 08:23 PM
brabham79's Avatar
i love it out here!
i have a scanner and will check it out when i get back in town next month. and no im not under warranty. so that always freaks me out when something weird happens.
so i have a dumb question about the thermostat...what do you mean change it? i didnt and did not know you could 'change' the thermostat.
GT3/GT2/GT Vendor Classifieds
Oct 13, 2015 02:07 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
Oct 2, 2015 02:23 PM
fanporsche
Sep 30, 2015 02:26 PM
