New brakes?
Old Apr 13, 2012 | 05:48 AM
  #31
RossL's Avatar
RossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond repute
Why do you wish you went with the Porterfields?
Old Apr 14, 2012 | 08:29 AM
  #32
Aston.Ca's Avatar
Aston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really nice
Originally Posted by 007 Vantage
I was never able to detect any trade off. The pads are a little but expensive, but not that expensive really. I guess the only real trade off of the 1521 is it's not a race pad for the track (but honestly who cares). In conjunction with the 2piece Brembo rears, the braking performance was borderline ridiculous (maybe even better than my lambo is now). The brembos make a massive difference IMO so if you are going to replace your brake pads you might as well do the rear brembo 2 piece rotors as well. The front Brembo kit is unnecessary and overkill, you can just upgrade pads up front.
Curious about this. I understand that the two piecers are lighter (and unsprung) weight and that the design should be more resistant to fade but do they also provide improved stopping power? Or is it the pad that makes the big difference there? If they provide improved stopping power on their own, is there a risk of poorer handling under breaking if the fronts are not also upgraded?
Old Apr 18, 2012 | 04:54 PM
  #33
sunir's Avatar
to the top!
Old Apr 18, 2012 | 05:54 PM
  #34
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
I assume 007 was referring to OEM diameter, 2 piece Brembo front discs. If so, I have to dissent and say from my own experience that they did not make a "massive" difference. Did they make some difference? Little if any that I could tell on the road, a bit of improvement on track, but I changed pads as well, and I suspect that was as important if not considerably more so. And if he was talking just about rears, not fronts, then I'm sorry, to me it is inconceivable how one would notice a difference.
Honestly, I can't imagine how insanely you'd have to drive on the road to get a gain from a floating, 2 piece front set up. Pads and cooling would be a limiting factor far before discs/rotors.
Do I have objective data (stopping distances etc.) to back up my statements? No. Would I recommend anyone follow this route if their OEM discs are in good shape (and would I do it again if same)? No. It's a case of diminishing returns IMO.
Would I recommend it if one's OEM discs were worn out? Yes, front only or front and rear, not rear only. Why not reduce unsprung mass and get a proper, floating setup, however small the perceived gains, as long as it doesn't cost any more than OEM?
Just my .02 ...
Old Apr 18, 2012 | 08:22 PM
  #35
Aston.Ca's Avatar
that's what I was confused about there. Maybe 007 can shed some light (not sure if he's been posting lately). But at $1600 for rears alone and OEM rear discs somewhere <$400 for a set if you shop around, not sure that I can see the bang for the buck there. And all the front sets I see come with Brembo calipers and are over $4k (!). Is is even possible to install the 2 piece fronts without replacing the calipers?. Regardless, that's a huge outlay IMO, I know there are some benefits, just not sure if it's worth the $$$ (particularly without a cooling solution for the fronts and the only one I'm aware of is the $1200 RSC kit).
Old Apr 19, 2012 | 01:42 PM
  #36
spinecho's Avatar
Precisely. If you can get the upgraded hardware for the same price, sure, but as you point out, that is not very likely.
As for cooling ducts, that's another problem area. IMO there is no functional option out there, apart from hacking into your OEM bumper (a big unknown) or changing to the factory race car or V12V front end.
Old Jul 25, 2013 | 09:05 PM
  #37
rotary rocket's Avatar
rotary rocket has a spectacular aura aboutrotary rocket has a spectacular aura about
Thank you Karlfranz, I was just about to buy some EBC pads. You saved me. Instead I bought a set of the R4S pads.
Cheers.
Originally Posted by karlfranz
The first mod I have done to my car is replace the pads with something less dusty. I helped a company called Porterfield Brakes develop the application for the Lotus Esprit. I was really pleased with how little dust their pads generated, so I decided to give them a try for the Vantage as well.
The pads I used are the R4-S which is their "street" compound. I would not recommend the R4 (race compound) pad unless you plan on tracking the car.
The front pads were number AP1165-R4S and the rears AP1166-R4S.
Here's a few notes on my install:
  • Both sets have the cutouts for wear sensors, but they are not located in exactly the same location as the stock Brembo pads. This was not a big deal as the sensor wire is long enough to reach the different sensor location.
  • AM recommends that you replace the sensors when you go to new pads. I'm guessing this is important if your sensors have already been scraped by making contact with the rotor. In my case the stock pads were still mostly new, so I reused the sensors with no ill effects.
  • The rear stock inboard pads are "handed" i.e. there is a left and right hand set. The difference is the location of the cutout for the wear sensor. In both cases, the cutout is designed so that the sensor is closer to the bottom edge of the pad, so the inboard pads are actually mirror images of each other.
  • The rear Porterfield pads were not mirror images, so on one side the wear sensor was closer to the top and on the opposite wheel, it was closer to the bottom. Again, not a big deal as the wire is long enough to reach either way.
  • The rear Porterfield pads came with an anti-squeal shim, the fronts did not. I reused the stock shims on the front and put the new shims with the rears.
  • I coated the shims and back of the pads with some Permatex anti-squeal compound. However, after driving the car, I had a terrible squeal from the rear pads (the ones that came with their own shims). I took the pads back off and replaced the shims with the old ones that were on the stock Brembo pads and the squeal went away.
  • The amount of brake dust on my wheels is now dramatically less than it was with the Brembo pads. This is exactly what I observed when I did the same replacement on my Esprit.
  • The pads cost about $150-160 per axle online. I did the labor myself, so there was no other expense.
  • I took a few pictures of the installation that I could post later if anyone is interested.
I hope this helps.
Old Jul 29, 2013 | 12:07 PM
  #38
mikes300's Avatar
mikes300 is infamous around these parts
Old Jul 29, 2013 | 12:17 PM
  #39
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Originally Posted by mikes300
Thanks Mike, glad to have had you on board!!!
If anyone is interested, I have sets of these lightweight rotors in stock and can supply along with the Porterfield R4-S pads at a very reasonable price.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Jul 29, 2013 | 06:25 PM
  #40
groutguy's Avatar
groutguy has a spectacular aura aboutgroutguy has a spectacular aura aboutgroutguy has a spectacular aura about
^^^ No Brainer! That's probably the best alternative out there!
Old May 6, 2014 | 01:11 PM
  #41
yawwn's Avatar
yawwn is infamous around these parts
Great information for when I buy an AM and require brakes.
Thanks all!
Old May 6, 2014 | 02:00 PM
  #42
rohnin's Avatar
rohnin is infamous around these parts
How much should a shop charge to replace all 4 brakes?
Old Jun 24, 2014 | 10:56 AM
  #43
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
Karl, reviving this older thread. Are you happy with the porterfield brakes? I'm thinking when time to replace might go with them. Amazed at the amount of dust from the oem pads!
Chris
Old Jul 4, 2025 | 04:24 PM
  #44
manuel2171s's Avatar
manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s
i didnt knew that, i changed my rear pads and didn't paid attention to left or right set.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
