slight rumble from 2-3K rpm :(
Old Oct 28, 2011 | 04:05 PM
meteoritesilver's Avatar
meteoritesilver
Hey guys. 27k on my vantage. Maintained. Original clutch seems to be good. Slight vibration and rumble in any gear from 2-3k rpm. Most noticeable in 4th due to sound/noise. Any help?
Old Nov 1, 2011 | 09:28 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
Ok. I'll take a hit at this one.
Are we sure its in the transmission?
I would take a look at the tires, check pressure, check if worn incorrectly.
If your in 4th gear at a certain speed, the tires could cause this if there cupped really bad, or worn.
It is hard to say with out hearing the noise, just going off what I have experienced in the past.
Old Nov 2, 2011 | 03:21 PM
meteoritesilver
thanks!! i'll inspect tires and variables re tires.
Old Nov 12, 2011 | 06:51 AM
meteoritesilver
not the tires
I've notice that the slight rumble happens even if the car is not moving and I'm simply revving the car. Why would she rumble like this between 2k&3k rpm? Strange. But I'm concerned. Would the clutch, if it were going bad, cause this?
Old Nov 12, 2011 | 09:58 AM
XJRS Owner's Avatar
Not trying to be an alarmist, but 'rumble' is a term often used to describe the sound/feel of crank bearings going bad. You need to localize the source of the sound if you can.
Old Nov 13, 2011 | 06:13 PM
meteoritesilver
crank bearings
Thanks. Is that an expensive repair? How do crank bearings go bad anyway?
Old Nov 14, 2011 | 09:28 AM
AMFixer's Avatar
If this is the case you are looking at a new engine. Aston Martin at this time does not rebuild engines, but this will be changing.
Is there any way to get a video clip of this rumble?
It is possible that you have a bad powertrain mount and it is causing you to fell the engine more.
It is hard to diagnosis this without really being there to see or fell your concern.
ams165
Cayenne 955/957
Oct 3, 2015 06:57 PM
Oct 2, 2015 02:23 PM
Bmanny
Sep 16, 2015 08:29 AM
Prefurbia
Sep 15, 2015 08:35 PM
dailydriver
Sep 13, 2015 09:01 AM
