Figured out why my wipers kept coming on
Old Nov 11, 2011 | 04:40 AM
boosting1bar's Avatar
boosting1bar is infamous around these parts
Water damage in the front fuse box, shorted out the motor making it come on at random times (when the key wasn't in the ignition...and dry). So now in addition to replacing the wiper motor I have to have the entire front fuse panel replaced as well. Ugh. They're estimating ~20+ hours labor.
Old Nov 11, 2011 | 05:55 AM
telum01's Avatar
Ouch...
How did the water damage happen?
Old Nov 11, 2011 | 06:12 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
20 hours to replace a wiper motor and a fuse panel???
Old Nov 11, 2011 | 01:26 PM
Irish07@VelocityAP's Avatar
I don't know how bad this damaged the front fuse box..but to replace the front "under bonnet fuse box". this is about a 1 hour operation..to replace the wiper motor(depends on the model/engine)..can take from 5-7 hours..these are all warranty times so some techs will be faster and some techs will be slower..hehe but 20+hrs is a little overkill, unless the harness is completely fried and needs to have all the pins redone to the fuse box under the bonnet.. even then seems overkill on the estimate..just my 2cents
Old Nov 11, 2011 | 07:55 PM
No idea, got the same labor estimate from 2 indy shops and the dealership so I suppose it's legit. They said the same, about 2 hours for the fuse box and the rest for the wiper motor. The shop I'm using I've been using for a couple years with my last two cars and my current other vehicle and he's always done everything surprisingly quick and way cheaper than the dealerships and is right on target with the other two estimates this time.
Old Nov 11, 2011 | 07:58 PM
Originally Posted by telum01
Ouch...
No idea.
Tomp
May 5, 2016 08:04 PM
97GtsMonster
Nov 17, 2015 12:38 PM
vbb
Aug 21, 2015 10:17 PM
TrackOne
Aug 20, 2015 12:56 PM
