V8 Vantage brake squeal
Old Jan 6, 2012 | 07:21 AM
RossL's Avatar
RossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond reputeRossL has a reputation beyond repute
Mikey,
Was this a long term fix for your problem?
Old Jan 6, 2012 | 12:09 PM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Yes.
They stripped the parking brakes cleaned and regreased the cable
They replaced one rear caliper, cleaned and reseated all the pads on all four corners.
Worked a treat.
Old Jan 7, 2012 | 06:29 PM
sonnyd's Avatar
sonnyd is a jewel in the roughsonnyd is a jewel in the roughsonnyd is a jewel in the rough
AML's latest solution
AML put out SB-06-0344 on 8 November 2011 titled Recommended Brake Maintenance Procedures. You can find it here:
http://tinyurl.com/recommendebrakeprocedures
It offers a two-step solution. First is the shims you all know about. Second is slathering the back side of the pads with TUNAP micrologic® PREMIUM 113 Brake Care+ brake goo:
http://www.tunap.com/en/ranges/autom...ucts/p113.html
I went looking for this stuff at the local car parts store, and the closest goo I could find was CRC's 05016 Disc Brake Quiet:<http://crcindustries.com/auto/?s=05016
The fine print for the CRC product says, "For use on the back of non-shimmed disc pads", so I wouldn't advocate using that product as a substitute.
SB-06-0344 suggests the use of brake shim pack with p/n 4G43-28-10789. I quick Google search of that p/n suggested it may be a Jaguar part number, but a call to the parts guy at my local Jag dealer proved otherwise. If one of you can source that pack from other than AML, please let us know.
ModBargains
GT3/GT2/GT Vendor Classifieds
Oct 13, 2015 03:55 PM
oo7
Sep 10, 2015 08:08 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
