Hard Brake Pedal & Whistling Noise
Old Jan 2, 2012 | 11:10 PM
Norman75's Avatar
Norman75 is just really niceNorman75 is just really niceNorman75 is just really niceNorman75 is just really niceNorman75 is just really nice
I'm having two different issues with my 08 V8V. One is the break pedal that is super hard when the car hasn't been driven for more than a day. The pedal becomes normal when I start the car but before that is hard as a rock. The second issue is a whining/whistling noise coming from the steering wheel/column when the wheel is turned full right or full left. Any of you encountered these issues?
Old Jan 3, 2012 | 10:13 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
The brake pedal concern might be normal. The only thing that gets me is after a day its hard. If the car is off and you press the brake pedal several times it will become hard. This is normal as there is no vacuum being supplied to the booster. The only thing I can suggest is check the check valve in the booster to engine hard line for leaks and or faults.
As far as the noise from the steering. If you reach full lock on the steering wheel by turning all the way right or left, you will get a whine noise. It is the power steering pump being (for lack of better words) maxed out. This is also a normal operation.
Old Jan 3, 2012 | 02:42 PM
Norman75's Avatar
I'll check it out thx for the answers
audipwr1
Sep 25, 2021 01:31 PM
rnl
Aug 26, 2015 02:36 PM
Zero911
Aug 24, 2015 06:51 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
