Figured Out New 2-piece Braking Solution ....
Old Jun 20, 2012 | 07:25 AM
  #61
zambono's Avatar
zambono has a spectacular aura aboutzambono has a spectacular aura aboutzambono has a spectacular aura about
well with that last post all is solved. BREMBO HAS DELIVERED THE DISCS Type III looks slick
Old Jun 20, 2012 | 03:30 PM
  #62
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Looks like I was right after all ...
Definitely worth getting a full set for those who haven't. I no longer see the point in upgrading to the 380mm fronts when can get matching 2-piece emplacements all the way around.
TypeV and Slotted looks like the best combo for matching front and rear
Old Jun 20, 2012 | 07:11 PM
  #63
SupremePower's Avatar
SupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud of
Actually they arent matching...the fronts would be Type V and the rears are Slotted. I am seeing if this will change in the future tho
Old Jun 20, 2012 | 07:25 PM
  #64
DetomasoGTS74's Avatar
Originally Posted by SupremePower
Brembo has just released the 2piece discs for the AM DB9 and Vantage.
Front MSRP $1895 355 x 32 2piece discs Type V
Rears MSRP $1595 328 x 28 2piece discs Type Slotted
How do they differ from these (link below) that have been out since March 2011? I noticed on their site they had said "big brake kit" and would assume they would require new calipers too if they are indeed bigger? Is there a 2 piece kit thats the same size as the standard rotors that we can take advantage of the lighter weight, or is this the same size as stock?
http://www.brembos.com/catalog/p1302...duct_info.html
Old Jun 20, 2012 | 07:56 PM
  #65
Not sure what was out in 2011 since Brembo North America just complete these last week. The new rotors are OEM size and are lighter weight and floating and a direct bolt on.
Not sure that that website is www.brembos.com is but its not the official site like www.Brembo.com or www.racetechnologies.com
Old Jun 20, 2012 | 08:50 PM
  #66
SupremePower,
Do you by chance have the exact weight specs of the new 355mm 2piece rotors? I know the stock rotors are roughly 28-29lbs, I just want to see how much weight savings the fronts would see compared to the rears.
As a reminder, rear stock rotors are 22 lbs, rear brembos were 13lbs, so roughly 9 lbs. if the fronts are the same then that would mean they are roughly 20lbs each. That would make a very significant difference in ride quality as well as handling dynamics.
Replacing with stock rotors has now officially become obsolete, might as well upgrade to the 2piece units for all the V8 vantages
Old Jun 22, 2012 | 11:44 AM
  #67
Pointby's Avatar
Pointby is infamous around these parts
That link shows rear discs, not the fronts. Rear discs have been out since 2011. The front AM two piece discs are new. It's confusing since all the images they show are of the type III GT3 discs, not the AM discs.
Both the front and rear discs are two-piece units the same size as stock.
Old Jun 22, 2012 | 02:12 PM
  #68
The front rotors are approximately 22 lbs from Brembo per side
Old Jun 22, 2012 | 04:43 PM
  #69
Wow great, so roughly 7 lbs reduction up front and 9lbs reduction in the rear. So for the full set that's 32 lbs of rotation unsprung mass!
That should definitely make a big impact in the way the car brakes, handles, accelerates, and rides.
If you have to replace your rotors soon, this upgrade/maintenance replacement is a no-brainer.
Is there any sort of package deal you can provide Supreme for a Front/Rear combo set of the rotors for those wanting to upgrade all 4?
Old Jan 10, 2013 | 09:41 AM
  #70
mikes300's Avatar
mikes300 is infamous around these parts
can you get them in drilled front and rear? if the hats are the only thing that's unique to the Aston, cant they just bolt on any disc that's the proper size? which seems to be quite a few that use those disc dimensions.
Feelgood MD
Mar 24, 2016 09:35 AM
Rockinc1
Sep 30, 2015 06:44 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
